solderdude
Good point.
Clamping force and construction are exactly the same so seal should also be the same when the same pads were used.
The original HD660S still came with the old pads and the S2 comes with the newer pads which are slightly different in the way the compress/sit so could be a difference.
How that would pan out on one's head ?
Granted the measurement below (Resolve) also showed the same difference on BK5128
HD660S2 seal measurements. however, do not show dramatic differences.
The HD58X (with the old pads) did show bigger differences.
So.. it is possible that the differences shown in the 5128 measurement could be seal related due to different stiffness/compliance of older pads vs newer pads where the newer pads thus have better seal and thus increase the lows relatively more.
