AnonymousAudio
- Joined
- Jan 31, 2025
- Messages
- 175
- Likes
- 123
Im currently in the market for a pair of Subs and figured i'd share my findings with everyone thats interested. I purposely am looking at (20hz & 31.5hz) as this is for a Home Theater sub application and my Speakers (SVS U.E. Pinnacles) will be crossed over around 40hz.
After some deep research going thru sub spreadsheets like the most popular one by (sweetchaos). Unfortunatly I found several errors. I tried reaching out to him for corrections and got no reply on his post. So I decided to make the corrections myself directly from the original source. Most notably all the Monolith subs which had incorrect readings due to an admitted mic calibration issue which Audioholics revealed back on 7/6/23. But that wasn't the only brand I came across with incorrect readings. My mini-chart has the corrected numbers.
*One exception are the Tonewinner subs, which were simulated to come to true Anechoic readings. This was due to the fact that they haven't been verified by Audioholics. Instead the measurenents came from youtuber (Spec of Tech). Whom uses compression testing in-room with a calibrated mic. By comparing his measurements to known Subs I was able to simulate his room gains and apply to the Tonewinner Subs for proper numbers.
I hope this helps those looking for the best Subwoofer for whatever your budget may be. If anyone has other Subs they think compare, I will gladly add them if their competitive. The ones currently on the list are what I found to be the most relevant for $2,500 and under. Enjoy
