Seenhaiser HD560s vs Beyerdinamic DT880 Edition 250 Ohm?
l3xtown
Which headphones are better suited for writing arrangements and beats?Seenhaiser HD 560s or Beyerdinamic DT 880 Edition 250 ohm? Which of these pairs will be versatile and enjoyable to work with? And also write your own version if there is one.
I answered you in that other thread when you asked the same question, HD560s New Version should be better than DT880 in this regard. HD560s New Version doesn't have the annoying treble peak and is better balanced overall.
Forget DT880, it doesn't have any sub bass for making beats, especially if you don't EQ them. With EQ you'll hit distortion before getting loud.
And in the first version, is 560 high still less than 880?
Can you recommend the top 5 headphones that are best suited for working at night and that open up well for arrangements and beats?
The DT880 250-Ohm is fairly balanced sound, slightly bright.
The 880 has a lot of top, I wouldn't say it's sharp, but low frequencies, smooth a bit but flooded. The mixes in them are detailed but bright, they are not good for the Rock direction.
Sadly there is no 'DT880', just like there is no 'DT770' nor a 'DT990'.
There are several differently tuned DT880, DT770 and DT990.
There are only 2 different tunings for the HD560S with the current one having the best tuning.
As Robbo already mentioned. The Beyerdynamics have a substantial treble peak.
Not a bad thing when monitoring/tracking during recording but less (actually not) desirable for music enjoyment.
The Beyerdynamics are a bit more comfortable and pads are cheaper (if you can get the correct ones).
The cable of the HD560S is exchangeable. The Beyers are not (they are fixed).
So... for the recording side the DT880 are fine (when an open headphone is required).
When also used for mixing you might end up with 'dull' recordigs (when one doesn't know the character of the headphone).
For mixing, music enjoyment I would recommend HD560S/HD400Pro/HD505/HD550.
b.t.w. its ... Sennheiser not Seenhaiser .... and Beyerdynamic not Beyerdinamic
Yes (first version has 3m cable)
There are many when you use some parametric EQ.
When not using EQ on recording side:
Sennheiser HD560S/HD400Pro/HD505/HD550/HD600, OLLO S5X, X1 DT880 Edition (with filter or mods), DT900proX, AKG K612, Audiotechnica ATH-R50x are a few usable ones
Yep, the Old Version (1st Version) of the HD560s still has less treble peaks than the DT880, and still also less bright than the DT880. The New Version HD560s is even less peaky in the treble than the Old Version (1st Version) - the New Version is better balanced and better sounding than the Old Version (1st Version) when both used at stock. New Version HD560s is the one to get when not using EQ.
Да, старая версия (1-я версия) HD560s по-прежнему имеет меньше высоких пиков, чем DT880, и по-прежнему менее яркая, чем DT880. Новая версия HD560s еще менее пиковая на высоких частотах, чем старая версия (1-я версия) - новая версия лучше сбалансирована и звучит лучше, чем старая версия (1-я версия), когда обе используются в штатном режиме. Новая версия HD560s - это то, что нужно, когда не используется эквалайзер.
Thank you very much for the detailed answer dear friend. Because on Reddit, on the contrary, they wrote that the first version is better than the second, like the second version is cheaper. Although here on the website, on the contrary, they say that the second version is better than the first. From the bottom of my heart. I'll order myself a second version of the HD 560. I wanted to order an 880, but I don't like their excessive brightness.
Thank you very much, dear friend, for the detailed answer. I use a translator because I don't speak English well. Well, I completely understood how to describe it. Thank you again
and what do you mean by mods for dt880? Is this a design change?
Thanks to every user who responded to this post, thanks for the reconstruction and disclosure of the topic. If you have any additions and suggestions on this topic, I will always be happy to calculate
You can put some toilet paper between the driver and the foam disc or use a passive in-line filter.
Then it is fine.
That's a bit subjective, but objectively if the old Beyer pads start to lose firmness even a little, then ears touching the inner walls hurts. 560S has less of that problem. Overall I find 560S much more comfortable than Beyer 770, 880, etc.
What solderdude mentioned, but not DT880. AIAIAI TMA-2 Studio is also worth considering although they don't get any coverage on this site. Other closed headphones (for more noise isolation) worth considering are Sennheiser 620S and Beyerdynamic DT 700 Pro X (I have these, but they are a bit heavy).
The Sennheiser 620S, how do they compare to the 560?
Tell me, please, how many 700 bass speakers do you have?
