The Dutch and Dutch 8C is about $12k/pair in the US. The Genelec W371A appears to be $18k/pair, and that’s not including a $6-$10k pair of Genelec 83x1s (depending on model). So total for the Genelec tower system would be around $24k - $28k, which is pretty extreme I think.
Yeah I've said before I don't really understand Genelec pricing in the US. It seems to be marked up 30-40% just because they assume US buyers are willing to pay more, I guess? I dunno. In Canada a pair of W371A + 8351B would come to ~$19000 USD. Which is almost exactly 50% more than $12,500 for the D&D 8C(they're not any cheaper here).
I certainly don’t see that as “worth it”, especially when unlike “The Ones” from Genelec there’s less of a clear picture what makes the W371A’s so exceptional and irreproducible vs other options. In contrast, there is absolutely no way I or anyone else I know of could DIY a speaker that measures as well as the 8351B, due to its relatively exotic design.
BTW I’m still a little unclear on what benefits the W371A’s offer that you wouldn’t get from a pair of much cheaper Genelec subs, for example. What’s the point of crossing over closer to 500hz when a Genelec 8351B presumably has plenty of SPL power at 100hz already? What exactly does “controlled directivity” mean for the W371A anyway, when I thought bass is inherently unavoidably more omnidirectional? And even so, what are the benefits here from the W371A that are not achieveable with a sub?
I agree it's a heavy premium to pay for the capability. But no, bass isn't unavoidably more omnidirectional. It's just HARDER to make it directional. As for why you'd want it, well, I'll leave that to our own
@napilopez's
descriptions of the benefits of cardioid bass in the D&D 8C. The alternative to good performing bass would be 2-4 subwoofers, but that wouldn't help you much with issues in the 200-500hz region, whereas the W371A can most likely make that whole region just about perfect out of the box.
As for SPL, it really just depends how much you need. If you refer back to
our old S&R THD diagram of max SPL, while the 8351B is improved I'm sure it shows the same pattern. The Ones are limited most by the region under 100hz but ALSO by the region between 100-500hz.
The vast majority of energy in music is around this region, and the 8351B already has quite a beefed up tweeter, so above 2.8khz has plenty of headroom.
So to truly remove the woofer limitations entirely and enable 110dB+ output across the whole range, you'd want a W371A, not just a subwoofer.
Do YOU need any of this? Probably not. But it is very very different from what subwoofers can do.
