As the title suggests I'm really hoping someone can provide a step-by-step idiots guide as to how to, once and for all, properly calibrate my miniDSP Flex Dirac Live version for a 2.2 music setup.
I've tried numerous times and either miss something or do something which later transpires is wrong (e.g. using MSO as I see now that Dirac enable miniDSP Flex is listed as incompatible) or follow a rigid process that I believe is correct and when it comes to the listening test sounds awful so therefore must have done something incorrectly!
I have the following hardware in my setup;
miniDSP Flex unbalanced with Dirac Live
Nord acoustics MP NC252 2ch power amp
Arendal 1723S THX bookshelf speakers (desk setup so quite near field)
SVS PB1000 Pro x2 subwoofers (placed about 9ft behind me close to the backwall with no option to relocate)
UMIK-1
I'd like to understand a full end-to-end process if someone is kind enough to draft one as i've seen high level bits and pieces online, or guides which become dated or don't account for nuance....etc what I'd really appreciate is full end-to-end process;
- Which mic cal file to use (given i have speakers in front, subs behind)
- Do i set XO first or later in the process? Should i high pass speakers or just low pass subs?
- For the routing matrix do i sent L+R channel both L+R subs or keep them separate?....etc
- Do i use REW to gain match & time and phase align subs and speakers, if so how and in what order? What options do i need to activate in REW.....etc - my current calibration sounds awful i think due to time alignment with subs being wrong so always hear a distracting boominess that sounds completely out of sync
- For the acoustic timing reference what is the correct way to use this feature to ensure time alignment is correct
- What stage in the process do i run Dirac Live calibration and how to ensure it improves sound rather than destroying any pre-calibration i've already done on subs....etc?
