Sean de Silva
- Joined
- Jun 27, 2026
- Messages
- 6
- Likes
- 13
I added the Decibelvibe TNZ SGE6 graphic equalizer to my system. I am not using it as a graphic equalizer. Instead, it serves purely as a real-time, 31-band frequency spectrum display.
I've spent years listening to vinyl, but listening is only one way of experiencing what is happening in that microgroove. I wanted to see what vinyl actually looks like in the frequency domain. What does a quiet passage look like? What does a click or scratch look like? What happens in the very low-frequency region that may be difficult to consciously hear? This curiosity was enough to make me get the TNZ SGE6.
I deliberately chose not to insert the unit between the PR100SE and AM100, as I wanted zero risk of it coloring the main audio path. Instead, the SGE6 is fed from the preamp Tape Out which is a completely parallel tap to the active source input. And this is where I encountered something rather more interesting than I expected.
Because the Atoll's Tape Out is a direct, unbuffered parallel tap to the input source, any electrical load placed on it reflects straight back and loads down the source component feeding it. The TNZ SGE6 has a relatively low input impedance of 10 kΩ. Connected directly to the Tape Out, it was loading down the output of the iFi Zen Phono 3 and I could hear an immediate degradation in the system's sound while adjusting the display sensitivity of the display. The presentation seemed less open. Dynamics and punch disappeared and the reproduction felt dull.
To remedy this, I introduced an active RCA distribution box between the Tape Out and the SGE6 input. The distribution box presents a much friendlier, high impedance load of 47 kΩ to the parallel tap, completely isolating the phono stage's signal while providing a properly buffered output for the SGE6.
The difference was immediately reassuring. The main system returned to sounding pristine and normal. This little experiment reinforced an important point : Even something that is supposedly "just a frequency spectrum display" still has to be electrically compatible with the equipment feeding it. The SGE6 itself wasn't the problem - the impedance mismatch was. It is a useful reminder that even an innocuous spectrum display can interact with a preamp electrically. Saying “it's only an RCA connection” doesn't mean impedance rules can be ignored.
So what does vinyl actually look like? This is where things become fun. Put a record on the turntable and watch the display. You quickly realise that vinyl isn't simply "music". The stylus is extracting everything contained in the groove - musical information as well as everything else that exists in the physical medium. The SGE6 gives you a visual representation of that constantly changing electrical signal. It is a classic case of analog playback physics meeting a highly sensitive 31-band spectrum display. The SGE6 has turned into a surprisingly useful window into the behaviour of my vinyl system. I can now watch what happens in real time across a variety of scenarios i.e. A silent groove, Lead-in and run-out groove, Groove noise, pops and clicks, Scratches, Low-frequency rumble, and, of course, actual music!
I wouldn't claim that the SGE6 tells me whether a record sounds "good" - the human ear remains the final judge of that. What it does provide is another sensory perspective. We normally experience audio through two senses: we listen to it and we feel it. The SGE6 adds a third: we watch it. And sometimes seeing the signal makes you listen differently. You start noticing things you might previously have ignored.
Final Thoughts
I didn't buy the TNZ SGE6 because my system needed it. It doesn't make my cartridge track better, it doesn't make my records quieter, and it doesn't improve the soundstage. And that is precisely why I enjoy it so much. Put on a record, lower the stylus, and watch the display come alive. Suddenly, the groove isn't quite as invisible anymore!
Final Thoughts
