Hey all,
I'm looking for just what the title says. Unfortunately, my google-foo has not been giving satisfactory results. More detailed requirements, in no particular order, are as follows:
I think the closest piece of hardware I have found for this is the Allo Piano found here: https://allo.com/sparky/piano-dac-2-1.html paired with an rPi, but I haven't figured out how to make it all play nice, since the Pi seems to be always set up as a streamer that can be connected to for music. I need a full time audio solution for all media consumption. I'm hoping you audio nerds (said with admiration) can help point me in the right direction here.
For reference, I am thinking about something like this combo with a Piano or similar attached to the back.
Thanks!
- Desktop-sized
- Good sound (Preferably tested by Amir, since I like measurements)
- 2.1 output over RCA (I have an amp for the speakers and an amp for the sub already)
- Room correction built-in (Work PC means no ability to install software)
- Under $200
- Preamp output (multiple devices used and Windows likes to randomly go 100% vol)
- (Nice to have) Ability to add a touch screen interface and run standalone down the road
Thanks!
