- Joined
- Jul 12, 2024
- Messages
- 3,630
- Likes
- 5,764
You aren't the only one. At least we know it's not AI.I don't get all your points...
What I am getting at the following. Take your genelec 8361/8351, insanely good speakers.You aren't the only one. At least we know it's not AI.
Where do the Genelec specs say this?Now check the specs, the genelec docs state lower than 0.05% harmonic distortion. SINAD barely at 70db
Both those speakers were recommended.In this forum, this ends up in a huge "NOT RECOMMENDED".
Most people don't. The first recommendation is always invest in speakers.Why spend 100's or 1000's of dollars on DAC and/or amp, while the bottleneck is the speaker and room acoustics?
That was quite a circuitous route to get to such a banal point, but few would disagree with you.And that is my point, optimize end-to-end.
Explain?Rationalize, symmetrical firing, so no contact sound, keeping neighbors happy.
What do you use for the home automation switch? Trying to work up a solution myself.I do not hear anything wrong so far. When pausing, silent. After 10 minutes, my home automation switches the kali off. When streaming starts, HA switches on the kali, the kali takes up to 5 seconds to wake up. With my phone, I can toggle the footswitch (esp32), sound changes, deep bass gone, bit higher bass is stronger. Soon, I will do some more REW measurements, with footswitch on/off. For now, I am totally happy with genelec/kali. But first, I will add the PCM5102 to my Arylic pro DIY streamer. Arylic stuff is burnt down to the ground on this forum, but sound is just great.
Hmm, and I tend to listen to the music, background noise just means you're not dead yet......
So tall that I use it as a table for my WiiM: is solid as a rock, no vibration at all on the enclosureThe new WiiM Sub is very compact and wireless, should play well with your WiiM Ultra. The Kali seems to be excellent as well but it’s pretty tall
I have home assistant with all kinds of esp32 and zigbee and 433.92mhz.What do you use for the home automation switch? Trying to work up a solution myself.
In my mind, the 85hz in the kali is just perfect for the genelec 8030. Going lower costs quality and SPL.So tall that I use it as a table for my WiiM: is solid as a rock, no vibration at all on the enclosure
Thanks for your recommendation: I considered the WiiM Sub as a good option with the Kali, the SVS 1000 Pro and some others.
My final choice sounds quite good, but unfortunately has an issue in the LFE mode that was discussed here in ASR (high self noise, peaked at 170 Hz and audible since 3 meters, not present in the by default crossover mode).
I’m hesitating to return it, apparently is an issue that is not yet fixed by Kali, so highly probable will be present on the replacement unit…
It works fine when using the classical path:
WiiM Ultra RCA stereo output => Kali WS 6.2 RCA 80 Hz stereo input => Kali WS 6.2 XLR stereo output => Genelecs G Three XLR stereo input.
But with this path I cannot play with the delay or the crossover freq.
Since the placement is close to speakers, probably not need for significant delay, and apparently sounds fine at 80 Hz…
Any advice?
You can find the specs in the operating manual at https://www.genelec.com/8351bWhere do the Genelec specs say this?
Agreed. I do know quite a few fanatics with expensive hypex/purifi/NAD/marantz, with crappy speakers, and loving vinyl....Most people don't. The first recommendation is always invest in speakers.
Maybe for you and me, but it seems that aficionados go for the 0.001% and lower.You aren't wrong that this forum salivates at the latest amps and DACs that perform well. However, most are low cost and affordable. More amps and DACs get reviewed because they are easier to ship and test. Don't mistake that for ignorance about speakers and room acoustics.
They don't publish SINAD which you said was 70. I'm wondering where that number comes from.You can find the specs in the operating manual at https://www.genelec.com/8351b
The kali has two chassis, firing in opposite direction. As a result, there is no mechanical movement in cabinet.Explain?Rationalize, symmetrical firing, so no contact sound, keeping neighbors happy.
Well, I guess you missed the part in the PDF that states THD 0.05% at nomimal powerThey don't publish SINAD which you said was 70. I'm wondering where that number comes from.
SINAD cannot be lower than THD. So, you agree that 0.05% (66db) is more than good enough?That's not SINAD. Missing noise.
But we are far off topic and the discussion is not helpful.
I don’t see any problem with 80 Hz, or at least by ear sounds good enough for me.In my mind, the 85hz in the kali is just perfect for the genelec 8030. Going lower costs quality and SPL.
I have my genelecs straight on a 3/8 inch mic pole with the thread in the base. Removed the rubber base base plate
I find that much better looking.
My ears cannot hear difference of the polarity switch on the kali, yet REW detects a very narrow and deep trough at 85hz in one position.
This seems compatible with the harman research, such a narrow gap is not audible. Switched it back, no audible difference.
85hz seems common everywhere, jbl, genelec, kali, adam. Translates into wavelength of 4 meter. SVS dropped high-pass filters.I don’t see any problem with 80 Hz, or at least by ear sounds good enough for me.
The reason of having 85 Hz as crossover frequency in Genelec subs can be more related with their subs than with the monitors.
Curious, why would that be?The crossover frequency, ideally, should be determined by room response apart from engineering.
I have a few more. As the videos of genelec explain, you cannot compensate a trough, other then improving the room.I have 2 main room modes at 40 and 70 Hz, and a 3rd at 140 Hz.
In my setup, the DSP is before the high/low pass filter, so independent. Sub has no DSP whatsoever.The 2 lower are handled by the sub, the Q factor is quite high so I don’t see any reason for preferring 85 Hz from 85 or 90 Hz.
In fact I tried 90, 95 and 100 Hz and I hear no improvement from 80…
Kali WS 6.2 has an inbuilt crossover fixed at 80 Hz, so I guess this is what they consider optimal to ensure enough SPL with their disposable power.85hz seems common everywhere, jbl, genelec, kali, adam. Translates into wavelength of 4 meter. SVS dropped high-pass filters.
On the advice of inactive member tangband, I compensated less than half of the measured peaks.
This is where the compromise kicks in, low/high volume, footswitch on or not.
As Floyd Toole explains somewhere else, you hear with your eyes as well.
Ear/brain already compensate for the room where you are in.
Emulating concert hall acoustics in your living room is a fantasy.
Reminds me, should do those measurements again, with/without footswitch. PCM5102 already added.
Yup, you are right. Assumptions .... My measuremnets showed the trough at 86hz. Docs clearly state 80hz.Kali WS 6.2 has an inbuilt crossover fixed at 80 Hz, so I guess this is what they consider optimal to ensure enough SPL with their disposable power.
Agreed. Bass will always be a compromise in a living room. REW has a placement simulation module. SBIR is another one IIRC.I think there’s no optimal, the room considerations is because you can install your subwoofer in optimal points to have a better response in your listening position.
Narrow nulls may not audible.For example, I have a big null between 90 and 110 Hz, if I move the sub for other positions I could have this null out of the sweet spot.
Why buy satellites with 8 inch, when planning for subs ;-)With respect to the crossover frequency, not having a lot of experience in subs, there are some considerations.
- The higher the crossover frequency, the less directional will be the lows in the upper bound of the sub. We have more directional discrimination at 120 Hz than at 70 Hz. I’m talking about just 2.1 systems, if you have 2 subs, no issue.
-The lower the crossover frequency, the more power the monitors require. And one can also expect more distortion, but this should be considered monitor by monitor.
You can play with this variables and your personal preferences. I like how the G Threes sound around 80-90 Hz, things changes a lot around 50 where the port begins to sound a lot.
Many users have big 8 inches monitors and they prefer 50 Hz crossover frequencies, no problem with this if the monitors can handle 50 - 60 Hz with authority.
What, sinad depends a lot on the components. In fact Amir never showed sinad for speakers, because it is irrelevantWhat I am getting at the following. Take your genelec 8361/8351, insanely good speakers.
Now check the specs, the genelec docs state lower than 0.05% harmonic distortion. SINAD barely at 70db.
In this forum, this ends up in a huge "NOT RECOMMENDED". Yet, insanely good speakers.
When optimizing for the entire chain, 0.01% or even 0.1% harmonic distortion is not relevant, compared to speaker distortion.
A good enough dac chip costs a few dollars, and real good class D amplifier is less than 10 dollar, e.g. TPA3255.
Broadly not understood, active speakers avoid high production tolerances, typical for passive crossovers.
And mind you, proper cross-over is critical for good spinorama.
Separate amplifiers also avoids intermodulation distortion across amps.
From the genelec teardown, I guess that the amp chips are IRS2092S, with separate power MOSFETS.
For the 8030 and 8330, distortion is even worse, yet not relevant compared to speaker distortion. TPA3118.
And that is my point, optimize end-to-end. Money spent on expensive DAC or amp cannot be spent on speakers.
So, insanely good amp or dac, it is just counterproductive. Put your dollars elsewhere for good sound.
Because an 8 inch monitor has limited low end performances, for example the JBL 308P covers to 45 Hz, and this part of the spectrum uses a lot of power from the amp.Why buy satellites with 8 inch, when planning for subs ;-)
In many cases, good spinorama needs three-way with an 8 inch.
Big speakers, big subs, not my cup of tea.
Well, in fact my null is not as narrow. I missed the gap frequencies.Narrow nulls may not audible.
