Keith_W
With your setup I think you will need to create the sweep file with REW "Generator". On the Top set of tabs on the "Generator" chose "Sweeps" and on the second row of tabs chose "Measurement" then fill in information the same as what you used before. On the third set up tabs chose "Save to file" and set up the channels and timing reference as before and click the "WAV" button. This will create a file you will use to measure. On the main REW Measurements Icon for Playback chose "from file" and navigate to and select the file you just created. Then load up the file into whatever "player" you are using then go back to REW click "Start" and then back to you player and start playing the file. REW will "listen" for the timing reference and when it plays will start the measurement process. You will probably have to create two files, one for the right with the left reference and one for the left with the right reference. Before you do the measurement make sure you have the volume on your player where you want it or you might be surprised. I usually use -20 dB when I Generate the sweep files to help prevent too loud playback accidents.
Why does he need to save a sweep to file instead of playing the sweep directly from his laptop?
