Nope, because WinISD does not support those. You'll need some other (more complex) software.@voodooless
Would it be possible to run the same simulation but with linear phase filters?
Thank you
Thank you
I tried to do a similar simulation, not specifically for that speaker driver but more generally for filters (that we apply to sealed cabinets)Nope, because WinISD does not support those. You'll need some other (more complex) software.
If anything, the "too slow" feel to the ported loudspeaker's response is simply due to its more extended bass response. The ported enclosure's extra output greatly affects a listener's perception in that regard. Of course, one area where the sealed enclosure excels is that it doesn't produce any noise from port turbulence at high sound pressure levels.Ok, we can say that artificially boosting up the closed response roll-off causes the same damage......still the group delay explains why the ported speaker has a "too slow" feel to it.
Ported speakers: Poor man's variant for bass reproduction. Also for men who are not allowed to place speakers of adeqaute volume in their living room.
Says you. My speakers are about 1.5cf internal volume, on no planet is that a "small" speaker... definitely ported, by the way.Ported speakers: Poor man's variant for bass reproduction. Also for men who are not allowed to place speakers of adeqaute volume in their living room.
Use EqualizerAPO software in a PC and stream from it. I have my CD collection burnt to JRiver and also use Spotify a lot. But any old sources like my CD player and BLURAY and Tuner in receiver aren’t getting EQ-ed as a result. A bit of a pain to have to use a PC and the display it requires. Changes the experience for sure from just using component audio.What's the easiest/cheapest way for a someone to apply PEQ in a domestic situation ?
I've compared the same drivers in the ported design below, put in a number of different sub designs, including sealed.
BMS 18N862Out of curiosity, what drivers?
Last time I checked, not really. It's 2 feet tall and 18" deep. Certainly fairly large...Is 1.5cf a typo?
I'd honestly put that on the small side of the scale for any speaker/sub handling the bottom end.
Maybe I've been away from a home audio focus for too long....?
Okay, if your standard for "large" is this, then sure, it's not that big. But that's the size of a goddamn refrigerator.I agree....with the cold hard facts at least.....can't say the same for the way they were expressed ...
Sealed subs with enough displacement to reach the lowest frequency, at highest desired SPL...without ANY bottom-end EQ boost......
...is the holy grail, .......given unlimited resources and a willing spouse.
Me? I've got the willing spouse, but alas.....resources only allow this man to have DIY ported subs.
If I could, I'd have a ton of single sealed boxes, where no boost needed, and I end up with no low end roll-off at all, at max desired SPL.
Anything sort of that is a "poor man's" solution
So, back to being poor.
When I boost sealed to match ported low end, and then run both without high-pass filters and at SPL levels below excursion risk...
....well, the slight audible improvement couldn't justify sealed.
I consider low SPL the absolute apples to apples best case for sound quality comparison. Adding high-pass filters to raise safe SLP degrades both, ime about equally.
If all you ever do is listen at low SPL, I can see the case for sealed.
But if you like to crank sometimes, ported simply adds too much SPL and low extension per $ spent, imso.
No, that frig sized sub is not my standard for large. It is over the top huge, and i only posted it as push-back to @Bach,Okay, if your standard for "large" is this, then sure, it's not that big. But that's the size of a goddamn refrigerator.
Just remember size matters! Go big or go home.@ posvibes, too funny !
to prove I had spousal approval for big speakers in the living room. His post kind set me off I guess.
But I think there was truth in his post that sealed is at least theoretically cleaner; and I do believe slightly audibly cleaner, than ported.
After getting sealed and ported transfer functions to fully match using the same driver, I've made a number of scoped microphone tone bursts / wavelet captures.
So far, the scope captures are only measurement I've found where they differ (after transfer functions are made to fully match).
Point here is, I'm probably overinvested in the sealed vs ported debate, and can take off half loaded lol.
Anyway, I kinda stupidly jumped in about physical size, because small, medium, or large speakers,.... that is clearly a personal judgement.
My apology for questioning your take.
Personally, I tend to put speakers into "size" bins, not so much according to physical size, but according to their measured low end acoustic output.
I think low end acoustic output/extension sets the foundation for the full speaker. And hence its apparent sonic size![]()
