- Thread Starter
- #81
One case stereo
sum to mono L+R
And vertical L-R
sum to mono L+R
And vertical L-R
Ok, I just meant for the resonance script. Not HTA... Sorry...One case stereo
sum to mono L+R
And vertical L-R
That looks like the normal print out in the console .
I use Spyder , in the console window the plot are supposed to be shown. Try Tools/preferences/ipyhon console/graphics and Backend= inline
Actually I did try the web app first and got the same result...something in your setting may be wrong, or not right track. I get such numbers if tracks are messed up. like using a horisontal modulated track for VTA, a vertical modulation is expected.
can you try the web app? are you using the lasted revision, rev 23?
The scrip is expecting 400:4000hz 6db vertical, as is the default. the fullpage script expect the whole side B. if you share the wav file I can try it..
did you use RIAA ? I guess you did with Accuphase… Do you see the option RIAA or not? The record is made without RIAA so the script need to reverse it if you record in RIAA.
Both option with and without should work , but things can happen. Are you on 33.33 rpm?
www.audiosciencereview.com
I am not at home can’t check file.
Are you using rev 23 , This one?
Script for intermodulation distortion testing of vinyl playback, setting VTA ,Zenith etc by test record
Hmm strange.. I get rev21=21.48, original web app=REV19= 22.70 Can you share the wav file? Web app rev21 Python rev 21 REV19 =original web appwww.audiosciencereview.com
