Script for intermodulation distortion testing of vinyl playback, setting VTA ,Zenith etc by test record
Thanks.
I have the STR-112, it has duotones with 4kHz and 400Hz lateral and vertical, and 200 Hz lateral and vertical, all with different levels of the intermodulation.
I think the results from such a test can only be compared to tests with the same record.
Anyway, the vertical intermodulations would be interesting to optimize VTA/SRA.
using the script...IMD results from the DIN 45 452 VTA test record, f1+f2=1000hz track mat maximum VTA...with mat.
Quite close to the specified 23degree
Tacet test record Antiskating/tracking test, script attached ,rename .txt to .py and edit file to match your recording
and with the analogmagik tracking track
And Ortofon 50-60-70-80-90-100um track
L-R phase difference for fun
note recording levels may not be exactly the same, these are old files I had, but all is with the same MC cartridge and TT /arm
using, a IMD vs time script... on CBS STR-112 test record, Sadly none of the track fit the 120mm null point. The numbers seem high, maybe because i recorded without RIAA
e
The vertical IMD track reacts with higher distortion when rising the tonearm base 2.5mm
Here is the time series script.
If you have a intermodulation test record with vertical modulation it can be used to set VTA for minimum distortion, or more..
The problem when doing this in REW is that wow and flutter cause the calculation to miss the peaks and calculation becomes incorrect..
This script has configurable frequencies to fit several records and are tolerant to some w&F...
Does calculate main IMD components, but not higher orders above 2nd and 3rd
Try it on your CBS STR-112 for example
PS : script is made using AI, after 26 revisions I decided to end with this version
Record is LB202 from East-Germany
A digital test track comparing script and REW
another script for time series phase difference and distortion, rename to py
