Hi all, may I offer some random thoughts/observations on MSO.....with the upfront realization i am far from an expert, just a guy who has tried a lot of sub deployments.
I like to think there are two basic strategies on indoor sub placement: one is to minimize modes, the other is to maximize them.
Subs outdoors tell me what minimization sounds like, and MSO indoors tells me what maximization sounds like.
Must say I prefer minimization by a wide margin....but is even more difficult to achieve indoors than properly implementing MSO.
A simple single sub in a corner is often the best minimization I can find. So MSO is often a well chosen compromise .
The measurement reciprocity technique, where you put a sub at listening position, and go around the room with a mic to find the smoothest reponse, is the best way I've found to determine optimal sub placements. That's held true for either a single sub, or multiples placing them in sequence one at a time.
Usually the first sub goes in the corner. After the first sub is placed, I'll apply a polarity switch and/or delays EQ on the second sub in the center of the room, again going around the room looking for now-combined response. It gets real confusing fast to try to vary multiples simultaneously ime. (BTW, subs don't really have the ability to adjust phase; polarity is almost always all the have wrt phase.)
There was a great question about can we feel air pressure waves from subs.....and i say without a doubt YES.
There was also a great follow-up reply distinguishing steady tones from impulses like come from a port.
Personally, I love the feel of a transient bass attack. And is a big part of why i prefer a single sub, with mode minimization when possible.
This may sound a little extreme, but an experiment that proves a physics difference to me, is playing an outrageous bass drop on a single strong sub, and then on multiples of the same sub. Picture an LCR setup where all three stacks have the same sub.
The measurement device is an empty beer can on a table about 15ft away from the center of the LCR setup.
The single center speaker can blow the beer can off the table. All three LCR subs make it jump and dance more or less in place, not leaving the table.
Ok i know that is extreme, but I personally think we feel this 'air impulse effect' all the time and is a part of our total hearing, which i think integrates bodily sensations with the ear.
But i digress...sorry..
Oh, If you're trying to figure out how much sub in terms of size and numbers you need, this handy piston calculator is a good starting place
www.baudline.com
