Sono
- Joined
- Aug 16, 2025
- Messages
- 78
- Likes
- 58
Found the closeted German.
Panel gaps must be uniform!!1eins
Hah har!
Logo. The eyes listen also with!
Me too, but I bet I could take the cover off and fix it in a few minutes.
I thought I bought the next 'best thing' for the price and recently traded up to a 3e[Soyyin]AudioA7.What's your perspective?
Not to worry. I'm sure it sounds every bit as good as a Benchmark AHB2 :>I thought I bought the next 'best thing' for the price and recently traded up to a 3e[Soyyin]AudioA7.![]()
Put some vase on top of the enclosure, it will press down the lid and reduce that gap
Cryptocurrency?how would it be paid for and shipped,
And a stealth jetCryptocurrency?![]()
Remarkable amplifier in its own right. Only its reduced power, according to the usage criteria of our time with inefficient speakers, could raise eyebrows. But anyone who has speakers with an efficiency equal to or greater than 94 dB could consider purchasing such an amp. Which is nevertheless much too expensive. But on the manufacturer's website, we can read that a user compared it to a very expensive and even less powerful French Lavardin amplifier! It seems that the Moscow hi-fi market is geared towards ruinous audiophileism where so many products are expensive and mediocre... so in this context, this amp is in its place... In any case, I read the white paper and their explanation of linear power supplies versus SMPS: these people are serious and the performance achieved by this amp is exemplary... Proof that class AB still has room for improvement...
The performance is good but agreed the price is about $3000 too much and getting it repaired would be a nightmare if needed.Fine performance, poor value => voted "not terrible" as a result
Without getting too wordy, the following was a news headline today:And a stealth jet
Repairs should be pretty easy, as I'd expect semiconductors to be familiar brands (if Russian opamps exist, I'm not aware of them), and power supplies are by Mean Well. I think it's pretty cool that @GydruS has dedicated himself to high-quality sound reproduction, but for now, export potential is limited.The performance is good but agreed the price is about $3000 too much and getting it repaired would be a nightmare if needed.
Is that not the purpose of the knob on the front: to reduce the gain? However, I would prefer a different implementation, perhaps with several switch settings, although I expect this linear configuration was chosen for the case where the user is driving the amp with only digital sources through a DAC.This amp is pretty sensitive. Standard for balanced connections is 4V, not 0.8V. In practice one will have to attenuate output of sources quite a bit.
Less gain might yield better performance.
That would be volume control. Havong this at max should yield maximum output. And maximum output should be achieved with 4V (2V unbalanced) input, as this is what contemporary sources deliver. Not 0,8V (0,4V unbalanced). I do not understand the reasoning behind this.Is that not the purpose of the knob on the front: to reduce the gain? However, I would prefer a different implementation, perhaps with several switch settings, although I expect this linear configuration was chosen for the case where the user is driving the amp with only digital sources through a DAC.
What's not to understand?That would be volume control. Havong this at max should yield maximum output. And maximum output should be achieved with 4V (2V unbalanced) input, as this is what contemporary sources deliver. Not 0,8V (0,4V unbalanced). I do not understand the reasoning behind this.
You can attennuate at the source for sure, but you risk loosing SNR by doing so.
The amp achieves it max power at 4.1 volt. If anything, it needs to be a hair more sensitive than the other way around.This amp is pretty sensitive. Standard for balanced connections is 4V, not 0.8V. In practice one will have to attenuate output of sources quite a bit.
