SCIBER AMPLOI Amplifier Review
Rate this amplifier:
    Votes: 35 12.6%
    Votes: 77 27.8%
    Votes: 128 46.2%
    Votes: 37 13.4%
This is a review and detailed measurements of the SCIBER AMPLOI stereo balanced amplifier. It was sent to me by the company and costs US $4,900.
The amp sets itself apart with somewhat unique styling that I like. The large footers allow for a set of RGB lights to show from the bottom that can dance to the tune of music. Lower feet are provided if you like less of an elevated setup (yes, the lights can be turned off). While volume control is provided, it and the preamp can be bypassed if desired:
Sciber stereo balanced AMPLOI amplifier amp xlr back panel bridge review.jpg
As you see, both XLR and RCA are provided as is trigger support.
The design is rather unique with use of switching power supply but class AB amplification using four LM3886 amplifier ICs per channel. The amplifier necessitates good sized heatsinks which anchor each side of the amplifier, giving it fair amount of heft although still lighter than one with linear power supply. In use, the top gets very warm and company nicely notes this as a "CON" of the amp!
The amp is designed and built in Russia and got lost in transit once so took a while to get here.
SCIBER AMPLOI Amplifier Measurements
I originally intended to only test the amplifier with the preamp/volume control in the loop. Here is that dashboard:
Towards the end of testing, I ran a quick test with the preamp bypassed removed and noticed better noise performance. So went back and re-ran some of the tests again with the by-pass enabled:
Sciber stereo balanced AMPLOI amplifier amp XLR amplifier direct no preamp measurement.png
This gets us essentially the same performance as advertised by the company (THD+N of 0.0005%). This is very good performance as you see in our rankings:
For RCA I only ran the test with pre-amp in the loop:
Back to XLR, here is the performance with or without the pre-amp engaged:
Sciber stereo balanced AMPLOI amplifier amp XLR SNR preamp bypass measurement.png
As noted, these are excellent results. Even with pre-amp engaged, crosstalk is reference quality:
Sciber stereo balanced AMPLOI amplifier amp XLR channel separation measurement.png
Naturally, the frequency response shows no dependency on load impedance:
Sciber stereo balanced AMPLOI amplifier amp XLR Frequency Response measurement.png
The dashboard revealed extremely low distortion which we see again in multitone and 19+20 kHz intermodulation tests:
Sciber stereo balanced AMPLOI amplifier amp XLR 19 20 kHz stereophile intermodulation distorti...png
Due to distortion being essentially constant, we get the excellent high frequency response above.
Power delivered matches the spec:
Sciber stereo balanced AMPLOI amplifier amp XLR Max and Peak Power 4 ohm measurement.png
There is a slight power drop at 40 Hz:
Best showing is in this distortion vs power vs frequency:
Sciber stereo balanced AMPLOI amplifier amp XLR Power 4 ohm vs frequency measurement.png
Finally, the amp is stable on power up:
It is clear the company aimed to squeeze the best out of the architecture they picked, leaving no stone unturned across all measurements. You can read about it in the company's white paper. Net results is objective performance approaching state of the art and well above average. Innovation is also provided in look and functionality with the RGB lightshow.
The cost is on the high side. I am not sure of economics of building such a product in Russia. So can't objectively say that it is too expensive.
I am going to recommend the SCIBER AMPLOI stereo amplifier.
  • Sciber stereo balanced AMPLOI amplifier amp XLR Power 4 ohm vs frequency measurement.png
Thanks @amirm
I think this is the first class AB with switching power supply that I have seen.
They did not choose more common design of keeping heatsink on the sides exposed outside for better cooling, probably to just make it look cleaner for expense of more heat building up inside causing top to get the heat.
the top plate seems to have vents from the pic, I might be wrong though.
Some pics from their website:
I know ASR doesn’t withhold recommendations based on value except in egregious cases but this is nigh approaching egregious. Good stats but not groundbreaking (B200 is ten times cleaner). And an amp’s most important job is providing power, and 64 watts is seriously unimpressive for this class.
Also…slava Ukraine!
For that price (5K) I would expect the amp to excel at something. This doesn't, so I'm not sure why someone would buy this product. It has no selling point.
I went back and forth on this so appreciate both points of view. Ultimately, I decided to reward engineering that has optimized a design fully, incorporating and valuing engineering.
Left/right heatsinks appear to be housed inside the overall enclosure... even with top/bottom venting, it makes you me wonder about heat management.
Reactions: EJ3
JSmith
