HI every one, I have the early Vidar power amp, and I detect a noise on both channels but more in the left channel, is a 65 Hz senoid signal, in my listening position is imposible to dectect or hear, but if you put your ear close to the loudspeaker drivers, you can hear it, and I discovered that noise increment if I pass my big toe close to the XLR, so I suspect there is a voltaje between the negative in RCA and the ground of the XLR, and I verify there isn't any noise from the transformer or mechanical resonance from the transformer. Have any of you had that noise detected?
