There is no such thing as musicality. Try to explain to me what it is, and you see it's not real.
A power amp has one job, that is to amplify an input to a larger amplitude. In my point of view a power amp is nothing but a very fast, variable power supply
Yes, exactly. If your amplifier is doing more than amplifying the input signal something is wrong. I do think it is helpful to have some objective criteria for a "good" amplifier which of course will vary a bit for every person and their specific goals. For me the baseline of "good" looks something like this:
1) Power: > 100 W x 2 in to 8 ohm, > 200 W x 2 in to 4 ohm, > 400 W x 1 in to 8 ohm, 20 Hz to 20 kHz
2) SNR: > 90 dB unweighted, 1 kHz, 5 W in to 4 ohm
3) Gain: > 19 dB, < 26 dB
4) Inputs: balanced (XLR or TRS)
5) THD+N: < 0.1% (-60 dB) at 45 kHz bandwidth, 20 Hz to 20 kHz, 250 mW to clipping
6) Frequency Response: +/- 1 dB, 20 Hz to 20 kHz, load invariant
7) Thermal Design: no fan, sufficient heatsinking to handle music at high power output
Michael
