- Joined
- May 22, 2020
- Messages
- 673
- Likes
- 925
Sounds like product and marketing at Schiit are not talking...Odd that it would report 32-bit support to the UAC2 driver, if that's the case.
They probably have an agency working for them to come up with the Schiit blow your mind our stuff doesn’t sound like anything and we won’t talk about it but yet it is awesome and if you want to be cooler than you already are buy some more. That’s the work of a professional ad agency. And that’s why they probably got the numbers wrong because they don’t realy understand the technology or what the specs mean and they probably copy and pasted the specs from another DAC they had in front of them and never fact checked it. I do find their web site entertaining but it’s all irrelevant to audio.I thought they were mostly the same people.
It’s good in house creative work.Jason Stoddard's LinkedIn says he founded an ad agency and worked there for twenty years.
How come Schiit's own AP report indicates that Balanced Out has a much higher noise floor? Am I missing something here?
Balanced Out:
THD+N Ratio (5/21/2020 2:00:26.278 PM) Ch1 0.009952 % Ch2 0.003431 %
THD Ratio (5/21/2020 2:00:26.278 PM) Ch1 0.000275 % Ch2 0.000235 %
Noise Ratio (5/21/2020 2:00:26.278 PM) Ch1 0.000160 % Ch2 0.000206 %
Single Ended Out:
THD+N Ratio (5/21/2020 2:05:15.761 PM) Ch1 0.000313 % Ch2 0.000282 %
THD Ratio (5/21/2020 2:05:15.761 PM) Ch1 0.000280 % Ch2 0.000246 %
Noise Ratio (5/21/2020 2:05:15.761 PM) Ch1 0.000138 % Ch2 0.000135 %
It's unclear, but i believe it creates a tear in the space time continuum that ends up growing and enveloping the earth ending all life as we know it. But you know, your mileage may vary.So what happens if I play DSD files through the Modius?
Have you been watching Dark? ;-)It's unclear, but i believe it creates a tear in the space time continuum that ends up growing and enveloping the earth ending all life as we know it. But you know, your mileage may vary.
Can't say that I have. Although it's either the tear, or the singularity and then we have Skynet to deal with.Have you been watching Dark? ;-)
What should it improves with external LPS?...Has someone tested it with an external Linear Power Suply? Any improvements?
You have the data to compare: The Modius measures better.How it compares with Su-8?
Meaning: every DACs are badly designed at first...?Every Dac improves with LPs.
Every Dac improves with LPs. For what I see it has a wallwart Smps. I will use it with Usb out from a Pi streamer.
Thanks
