Why?my Midgard is now surplus since rhe arrival of my RME dac.
if anyone interested in UK, please pm.
will post proper ad in next couple of days
Isn't the Midgard the better AMP of the two?
I rarely touch the volume, it hasn't ever been an issue for me ;xI quite disliked the 'noisy' volume pot though. It's like you hear the dust inside of it over time.
Topping L30 or A90 for me! As a natural development after the 789 release, I meanOR the superb A20h but it seems it is end of life : (
it has more power but thats it.Why?
As for volume control, in order of preference I set it on the amplifier, and if there is no other choice, on the DAC. Always at 100% on the PC or any other platform running the player application.Question 2 -
is it better to reduce the computer's digital volume and keep the amp's volume higher, or will that degrade the sound quality more than setting the computer's volume to max and using the amp's lowest possible analog volume, even if it's still a bit too loud?
it depends on the implementation. If the OS audio stack is not used to avoid resampling (like, in Windows, using WASAPI exclusive or ASIO audio protocols for connecting to the external DAC), then system volume is not available; the only volume control is the one provided by the player APP.What happens if one would set the volume on the computer itself?
Schiit makes lots of products... the official spec is 3W idle, which shouldn't be very warm at all.Anyone that owns this amp can you answer two questions?
1. Does this get as warm/hot as Schiit’s other products?
Don’t want to add to my ambient room temp if I can avoid it. My Topping L30 died and it was fairly cool running.
I had the JDS Labs Atom, and It was not that good with (ultra) sensitive IEMs.Anyone that owns this amp can you answer two questions?
2. How well does it measure and perform at say 50mW or other low loads for IEMs?
I had a Schiit Jotunheim in the past that not only got hot (added to the rooms ambient temp) but also had awful static noise for IEMs not much different from just using the built in amp on my old thinkpad.
As a result I had to have two setups, a dongle and a headphone amp for my planar cans. Would like to have one amp or combo that can do it all.
Been thinking of JDS Atom 2 Amp/DAC combo or going for SMSL Raw or something similar. Heat and how they do with both headphones and IEMs are my primary concern.
Very helpful, thank you for taking the time to do all those tests.These are the temperature and power consumption of a Schiit MIDGARD.
The MIDGARD case was made of steel and painted black. A similar RME was placed a short distance away. The RME was not connected to anything.
The doors and windows in the room were closed. The air conditioning equipment was turned off.
The power consumption measurements are fine, but the absolute values for temperature are probably inaccurate. Since it was a hassle, I measured it using the FLIR with its initial settings. I think the temperature difference would be helpful.
The 72.7°C part corresponds to the LED on the board.
The temperature was measured about an hour after turning it on. The room temperature gauge read 27.5°C.
