i am not sure.
i use the mathaudio plugin on foobar and believe it calculates this automatically, but i cant see how much .
i must have glanced over this when i read the full post."Balanced between E50 and Midgard will be 50% louder."
I'd still recommend you use Oratory's preset.balanced leads sorted me out.
plenty loud enough at 12 o'clock now in hi gain, with Amir's eq profile
www.audiosciencereview.com
Many thanks for the measurements!Measurement of the input impedance and line output impedance of the Schiit MIDGARD.
Yes, my Midgard is as you corrected.
The Midgard has had that spec since its launch:Yes, my Midgard is as you corrected.
However, I bought it more than two months ago (from Schiit), so I can't rule out the possibility that it has recently become version B...
I hope it's been translated well.The Midgard has had that spec since its launch:
Edit:
Ah you mean it's possible you bought a silent revision and Schiit haven't updated the website yet. Got it.
I would think that even if they made a "silent revision" they would need to update the specs on the site because it is still technically wrong for what someone is purchasing.I hope it's been translated well.
If I understand correctly, your sentence before the edit and my original scenario are the same.
However, with your point, my original scenario has disappeared.
The only hope left is the scenario where "I just bought the new version that has recently undergone a minor change, and the official website has not yet been updated." It's exactly as your sentence after the edit says.
If this is not the case, it will be confirmed that the notation of Zin and Zout was full of mistakes from the beginning...
Yes, to sum up, "For now, I have high hopes for Schiit. Please fix the specifications soon."I would think that even if they made a "silent revision" they would need to update the specs on the site because it is still technically wrong for what someone is purchasing.
Schiit has made an effort to do better in the recent years. While they aren't a company that I like; I can respect their efforts.Yes, to sum up, "For now, I have high hopes for Schiit. Please fix the specifications soon."
The official specifications must be updated correctly at the same time as the updated product starts accepting orders.
The ideal time lag is 0 seconds.
"Spec changes without notice" are common, but if possible, I would like the details of the specification changes and the date and time of the change to be announced a few months in advance.
This measurement was triggered by a question about the input/output impedance values of other Schiit products posted in another thread.
The photos and screenshots are real, so I posted them. There is no problem in practical use, but fraud is not allowed. I would like to believe that Schiit is making an effort.
It is a bit surprising that it has balanced input and output, BAL/UNBAL mutual conversion, RK27, and preamp, has sufficient performance, is manufactured in the USA, and costs 219 US dollars. The XLR3 Zout is 600ohms, which is not the norm these days, but the low range is flat, so it is probably not a problem.
I measured the left and right volume deviation in several places and found that it was very small. The specimen sent to Amirm does not seem to be a golden sample.
I sometimes see APx screenshots from other manufacturers that are fragmented or have unclear measurement conditions, but Schiit publishes the report output of the APx software as is. (At least the measurement conditions are clear.)
No.Using low impedance HPs (e.g. IEMs, Austrian Audio, Focal, Sony, etc.);
Will I hear any difference between using the Schiit Magni Unison and the Midgard? (using as AMP only)
My listening levels never pass 80dB of course.
Yes.Is the same regard to HO150X vs Magni?
Utter nonsense(I read about Topping and THX AMPs being very 2D in their sound presentation)
Exactly. The 789 is one of the greatest amps ever created.This is fake internet talk. A THX was my main amp for years, upgraded from an Asgard 2. Plenty of clean power on tap. The only issue is my SP200 has a channel imbalance at very low listening volumes, so I switched to the Midgard for planar/dynamic listening.
