Schiit Midgard Balanced Headphone Amp Review
Rate this headphone amplifier:
    Votes: 6 2.5%
    Votes: 5 2.1%
    Votes: 54 22.3%
    Votes: 177 73.1%
Thank you for your reply. I own the MOTU M2 and I use it primarily for my microphone for gaming and discord. My main question is will I benefit from greater soundstage and a little bit more warmth in upgrading my L30II to say a Midgard without also having to buy the Modius. I apologize that Amir's test don't help me as they should as I am a laymen when it comes to the technicality of his test charts. Still learning. :)
DACs have nothing to do with soundstage. Soundstage comes from the source material and then your headphones or speakers.
According to Amir's review, you should be ok with the MOTU you already have.
Thank you, Brian. I appreciate you taking the time to answer my questions.
Oh, I got this email from Schiit today:
Hi,
I have a FiiO K9 AKM, that has a THX AAA 788+, and a Ibasso DC Elite coming. I was considering getting rid of the K9, buying a Schiit Midgard and use the DC Elite as a desktop DAC with the Midgard when I want to.
My question is if I'll get any improvement in sound quality just changing de amps, all else being equal.
Thanks!
Edit: spelling
Hi,
Thanks!
Edit: spelling
No you don't get an improvement in sound unless you're driving very hard to drive headphones such as Hifiman Susvara where the extra power from Midgard is needed
Has anyone tried pairing the Midgard with the ModHouse Tungstens? Would love to hear your impressions of how it went.
pardon my ignorance ....... i have a fosi ZD3 DAC with a fosi ZA3 amp using this to connect them https://www.amazon.com/gp/product/B08XQQK59H/ref=ox_sc_act_title_1?smid=A2JAH816F3JQTD&psc=1 . i've been using the ZD3 rca outs to a "closeout" schiit magni heretic . i have zero problems with the heretic ..... however the better half's 3-4 year old fx-audio dac-x6 bit the dust soooooooo i have a "reason" to upgrade :) .
my plan is to give her my few months old heretic and order her a SMSL su1 and she should be good to go .
the midgard looks to be all i want and more , but i have a question about if the balanced in and balanced out stay balanced all the way through . the balanced looking HP out on the front isn't balanced but to make use of their halo system (that i may never use) so i want to be sure that doesn't compromise the balanced in/out signal path . FWIU on the fosi ZA3 the balanced out is cleaner/better than the RCA out . also FWIU on all or most DACs with balanced and RCA out the balanced are typically cleaner . i don't have any noise issues . i just want to get something fairly decent .... maybe have some bragging rights to make me feel better about my little buddy :( . i use tygr 300-r HP's but i sure want to try a pair of planars in the near future .
should i be good to go with the midgard ? is there something else with balanced in/out that i may want to consider ? i'm not gonna get on my asian made computer/phone and talk crap about only buying American .... but it is part of the reason i got my heretic from them as i do like to support American made when i can afford to .
thanks folks and be kind to this audiophool .
wondering if my Midgard is goosed?
powering my eq'd HD800s i can max volume out on high gain.
surely this should be uncomfortably loud?
on my Project Ember i can only get to 12 o'clock on the vol before its too loud, on LOW gain.
on my HP8 tube amp i cant quite get past 11 o'clock before its too loud.
all using same dac, btw.
Not necessarily.
If the input voltage is low enough, then it'd be easy to max out the Midgard's volume without it being uncomfortably loud.
You can use a basic $15 multimeter to check that your Amp is in working order.
For this, play a 60Hz test tone on any DAC, then set the multimeter to V AC and measure the voltage before and after the Midgard, with the volume knob turned all the way up.
Gain in dB is 20*log10(output voltage/input voltage)
In Low gain, you should be seeing about 0dB, so identical input and output voltage, while in High gain you should see roughly +13.16dB.
The Project Ember has considerably higher gain than the Midgard's high gain. You'd need a DAC that outputs about 3vrms full scale to not leave some volume headroom on the table with 300ohm load.
even with Ember on low gain?
Gain of the Ember is solely tube dependent (so not fixed) and for that reason one can attenuate the input signal.
have been thinking of moving the Midgard on and my E50, in favour of an ADI-2 dac.
how can i be sure i wont have the same issue powering the HD800s with same eq?
Had a hearing test lately? That may have become a volume issue as we age...
