Schiit Magni Unity DAC/HP Amp Review
Rate this DAC & HP Amp
    Votes: 25 13.5%
    Votes: 107 57.8%
    Votes: 48 25.9%
    Votes: 5 2.7%
This is a review, listening test and detailed measurements of the Schiit Magni Unity Headphone Amplifier with its optional DAC. It is on kind loan and costs US $199 as configured.
In black, the unit looks serious and attractive. Typical of Schiit products, there are no display and hieroglyphics are used as labels. Due to simplicity of the amp, the latter is not a big deal.
Back panel shows simplicity in the limited connectivity:
Schiit Magni Unity stereo DAC headphone amplifier back panel ac transformer review.jpg
Only USB-C is provided which is fine by me but others may want coax or toslink digital inputs as well.
The transformer is the familiar Schiit fixture which bucks the norm of using switching power supply. Left plugged in, it uses enough power to stay warm.
One annoying thing is naming: I have lost track of how many "Magni" amps Schiit has released. This one is called Unity but you wouldn't know it unless you looked in the back.
Schiit Magni Unity Measurements
For most of the measurements, I used the Unity as a combo DAC and headphone amplifier. Let's look at how its DAC performs using RCA out in the back:
This is the best results I could get. When I first plugged in, Ch1 (Left) was way down at 95 dB. Ch2 (Right) climbed up to 102 dB but then would dip down to 96 dB. I messed around with grounding and messed around some more and all of a sudden got the above result. I have not seen this level of sensitivity in hardly any products. Whether you see the same thing when you hook the unit up in your system, I can't say. As is, performance lands in competent category:
In this day and age though, I expect better. Ditto as far as dynamic range:
Schiit Magni Unity stereo DAC headphone amplifier Dynamic range measurement.png
IMD test shows the same noise issue:
The dashed blue line is a $250 device that came out 5 or more years ago.
Filter implementation is rather typical:
Schiit Magni Unity stereo DAC headphone amplifier Mesh Filter measurement.png
Frequency response is excellent as I would expect:
Schiit Magni Unity stereo DAC headphone amplifier frequency response measurement.png
What is not, for this class and brand, is linearity:
So many DACs nail this test that I have recently stopped running it. But here we are, with a DAC that starts to lose accuracy before the sweep is over.
Multitone test turns in decent but again, not competitive response:
And there is that one spike above 10 kHz which is kind of strange. But not nearly as much as jitter test:
I thought days of getting responses like this was over. Clearly no attempt was made in keeping DAC output clean.
We see yet another manifestation in our wideband distortion+noise vs frequency:
Schiit Magni Unity stereo DAC headphone amplifier distortion and noise vs frequency measurement.png
It is not filter related as higher sampling rate barely lowered it. So I ran the wideband FFT test:
Schiit Magni Unity stereo DAC headphone amplifier 1 kHz FFT noise and distortion measurement.png
A lot of junk is out there, below and above 20 kHz. Fortunately likely not a bother to the ear but my eyes are popping out!
Inclusion of negative gain in the form of lowest gain saves the unit in that department when it comes to headphone output:
Schiit Magni Unity stereo DAC headphone amplifier power 300 ohm measurement.png
Schiit Magni Unity stereo DAC headphone amplifier power 32 ohm measurement.png
And lots of power as well. Distortion does rise though at the limit, especially with low impedance loads.
I specifically tested for noise for sensitive IEMs and response there is again quite good:
To see if the DAC is holding back the pre-amp, I ran the SNR rest both with digital and analog inputs:
Basically they are the same with tiniest edge to analog input.
Oh, I forgot to run the channel match.
Schiit Magni Unity Headphone Listening Tests
I did some listening tests using my Dan Clark E3 headphone which has a 27 ohm impedance. Up to about 3:00 o'clock on the volume control, the sound was excellent on my reference tracks. Above that, which starts to become loud, distortion started to set in with sound getting brighter and crunchy. To be sure it was not the headphone, I switched back to my Topping DX5II unbalanced out. Not only the Topping get louder, it stayed gorgeously clean and produced dynamic range far beyond the Magni. I know, not a fair comparison given the $100 price difference but just making the point that the Magni is not the "end game" the company says it is.
For a while, we had it good with Schiit, with the company stepping up its game and producing excellently measured DACs while being price competitive. The have kept the latter but alas, it seems that they have slipped backward. The DAC simply lacks the hygiene we expect these days. The headphone amp is powerful for its class and triple gain settings is nice. If you don't need to have it drive very low impedance headphones at high output levels, then you are good to go.
Overall, I am reluctantly recommending the Schiit Magni Unity with DAC. Company can and should do better.
SPECS THAT MATTER
Power:
plenty for all headphones except a handful of the hardest-to-drive ones (we’re talking HE6, Tungsten, stuff like that)
Noise: inaudible on all headphones and IEMs
Distortion: unmeasurable at normal listening levels; 1000x lower than the typical headphones you're using
Heat: amp gets slightly warm without DAC card, moderately warm with DAC card; this is fine, we have made much hotter-running stuff that lasts farrrrrr past the warranty
Size: extremely desk-friendly
OTHER SPECS
Frequency Response: 20Hz-20Khz, +/-0.01dB
Output Power
Maximum Power, 16 ohms: 3.0W RMS per channel
Maximum Power, 32 ohms: 2.5W RMS per channel
Maximum Power, 50 ohms: 1.5W RMS per channel
Maximum Power, 300 ohms: 415mW RMS per channel
Maximum Power, 600 ohms: 220mW RMS per channel
THD+N
Low Gain: Less than 0.0001% (-116dB) at 2V RMS into 300 ohms
High Gain: Less than 0.0003% (-108dB) at 2V RMS into 300 ohms
IMD
Low Gain: Less than -110dB at 4V RMS into 300 ohms, CCIF
High Gain: Less than -108dB at 4V RMS into 300 ohms, CCIF
SNR
Low Gain: Greater than 122dB, referenced to 2V RMS
High Gain: Greater than 112dB, referenced to 2V RMS
Crosstalk
Less than -80dB, 20 Hz-20 kHz, 300 ohm load
Output Impedance
SE ¼” TRS output: less than 0.1 ohms
Preamp output: 75 ohms
Input Impedance: 50k ohms
Gain: 0.3 (-10dB), 1 (0db) or 5 (15db)
Topology: Fully discrete, DC coupled, current feedback, highly linear open-loop with low loop feedback
Protection: Failsafe DC power input and muting relay, overcurrent sensing and output lift, DC servo
Power Supply: 100% linear supply with “Wall wart” style 14-16VAC transformer, regulated +/-17V rails with over 8,000uF total filter capacitance
Power Consumption: 2W idle, 12W max
Size: 5 x 3.5 x 1.25”
Weight: 2 lb
First!!!
Another Schitty product from Schitt CO
Thanks Amir, you must be burning the midnight oil!
Another slightly surprising test - "not terrible" for me.
Competition is intense from the East.
Thanks again Amir, you really are on a role at the moment.
FWIW 15 of the last 17 products that you have reviewed have been less than $1k. Only 10 years ago we were being presented with DACs and power amps of only mediocre quality for well over $5k each, and now we have complete SOTA systems (plus speakers) for less than $1k. Great time to be an audiophile.
Thank you for the detailed review.
Your conclusions above are highly suspect regarding the design quality of the device. A test of another or more copy of the same device would be useful to check if there indeed a problem inherent to the design indeed, or if this behavior it is related to the particular copy that was sent to you.
They keep trying 100 different ways to recreate the wheel, using all sorts of Proprietary Technologies™ with Funny Names™... Only to perform worst than common off the shelf solutions. To me it feels like it's the designer's hobby rather than designing a truly better competitive product. Same as Nelson Pass playing around with exotic designs in his First Watt amps.
Yes,
Amir gives a sample size of one to add to the collection of data.
I regard his paragraph as reporting what he found in his sample.
With this price don't think it is Engineering job but marketing department throwing some buzzwords into it. For $199 dac + headphone amp that assembled in USD not much budget for R&D to try new things, even if they want to
They are a designing company for sure with lots of marketing involved. And a cult following.
Just read the book thread here, latest chapters about their designs.
The problem with products like this is when done/connected right it increases performance and value. Nevertheless, these problems do exist and I don’t have a $(x?)xx,xxx audio analyzer at home to verify, therefore these product always get a pass in my book as performance is unknown/unpredictable.
Looks like you don't know them. They are a designing company for sure with lots of marketing involved. And a cult following.
I was referring to this specific product. At this price point no matter what words they throw into it audiophiles will not buy it because it is still so cheap.
Looks like this product is at "end of life". Schiit is listing it now as "last call". No longer in their product line up depending where and how you look (search engine).
Thanks for the excellent review Amir.
Quite disappointed. As I recall, without going through multiple reviews, Schiit products have generally been above standard. I always liked that they are (designed?) and assembled in America, as so few audio products are nowadays.
Hopefully there will be a replacement that resolves the issues with an updated version.
I'd expect power noise to hit both channels at the same time, for something to be unstable and hit one channel at a time could it be oscillation?
I think the way to go with Schiit is through separates—like using the outstanding Magni Heresy with one of their DACs.
Not withstanding this performance hiccup, they have shown many times they have engineering chops.
A *consistently* excellent American made-and-designed product manufacturer is JDS Labs. They are just . . . wow! I’d like to see more products measured and evaluated here like they used to be.
And same with Geshelli. They seem to have disappeared from ASR, but they used to put out consistently great, American made and designed products.
So, more JDS Labs and Geshelli product reviews again, please!
