Schiit Magni replacement for Akg 712
saelwen01
Hi I am currently using Akg 712 with a schiit Magni and a topping d10 the Magni is getting pretty old and I was wondering what to replace it with alongside if I needed to upgrade the topping d10 ( i don't have the 10s)
Budget 170 euros/2000nok
I think it would be wiser to invest in some better headphones, but you could also go for something like a Topping DX3 Pro+ to replace both HP amp and DAC and tidy up your setup.
*edit* Actually, the DL100 would give you balanced connections which can be a massive benefit if you ever want to connect active monitors to your setup...
