VientoB
Yeah, I guess that's the amp reaching it's limit.Amir actually wrote this about the Magni Unity (a listening test)
Well that was pretty accurate. Clipping sounds bad, another amplifier has more power and is cleaner. That’s very informative.Amir actually wrote this about the Magni Unity (a listening test)
That’s actually not good at all. Headroom is important, clean amplifiers are important. More transducer damage is done by amplifier clipping than too much power.Possible as 118dB peaks would be the limit the Magni - E3 combo can hit.
The also mentioned DX5II in S.E. mode has the exact same output power level though.
For speakers there are cases where that may happen but not so with headphones.More transducer damage is done by amplifier clipping than too much power.
Nah, too much power is too much power.That’s actually not good at all. Headroom is important, clean amplifiers are important. More transducer damage is done by amplifier clipping than too much power.
I do own headphones, and iems but I consider myself an occasional headphone user. Speaker much more. That was what I was thinking about mostly. For me it’s hard to imagine playing headphones that loud and long to damage them, without developing serious hearing loss eventually.For speakers there are cases where that may happen but not so with headphones.
They get damaged by too much power or a DC voltage.
Technically, it is very necessary to increase the number of taps. AKM and ESS chips only work with a few hundred, Mesh 18k. The 16-bit precision signal reconstruction of CD PCM requires mega taps.Well, it’s not a disaster and most performance is respectable, but the USB noise interference raises eyebrows. Price is low-ish but performance on the whole isn’t competitive with the best in its price class. Plus, Schiit has shown they have engineering chops to make excellent gear—just not here. Taking all of the above into account, realizing the deficiencies will probably not be audible unless you have a really noisy USB source, I’m voting “Fine.” However, it is an almost “Not Terrible.” Really on the line here.
Actually it seems all these extra taps are not helping much with low level resolution...Technically, it is very necessary to increase the number of taps. AKM and ESS chips only work with a few hundred, Mesh 18k. The 16-bit precision signal reconstruction of CD PCM requires mega taps.
Amirm does not measure the bit accuracy of reconstruction, it really should.
Example Topping DX5 II (ESS ES9039Q2M).
SMSL SU-1 (AKM AK4493S).
Why would it be telling?I mean the difference between the ideal complex signal and the reconstructed one. This cannot be measured directly, but it would be telling.
Because this is the most accurate characterization of signal fidelity, that is, the maximum of signal deviation.Why would it be telling?
Would it be audible? If it doesn't show up in the usual measurements why would it be audible?Because this is the most accurate characterization of signal fidelity, that is, the maximum of signal deviation.
It would show the justification for increasing the tap number.
Better spatial perception, more natural sound.Would it be audible? If it doesn't show up in the usual measurements why would it be audible?
Those aspects are in recording and somewhat modified by the room/speaker. A DAC has nothing to do with them, much less their filtering.Better spatial perception, more natural sound.
What phase error?The SINAD value is misleading because it does not show the phase error.
As I know, the task of filtering is to reconstruct the signal shape, by interpolation. If this is not good enough, the spatial sense and naturalness deteriorate. The theory requires Whittaker-Shannon interpolation and a sufficiently good approximation requires a lot of computation.Those aspects are in recording and somewhat modified by the room/speaker. A DAC has nothing to do with them, much less their filtering.
Apparently you never came across Shannon-Nyquist while you were studying. I suggest watching this video:As I know, the task of filtering is to reconstruct the signal shape, by interpolation. If this is not good enough, the spatial sense and naturalness deteriorate. The theory requires Whittaker-Shannon interpolation and a sufficiently good approximation requires a lot of computation.
Excellent SINAD values can also be achieved with less computing power, but it is misleading to conclude from this that the signal reconstruction is accurate.
At least, this is the conclusion I came to while studying PCM.
Can you please point out where I am wrong?
That's not what it does. It is a simple low pass filter to get rid of high frequency artifacts. There is no intelligence to shape anything. Most of the time, the job is not interpolation but sampling down.As I know, the task of filtering is to reconstruct the signal shape, by interpolation.
