Schiit Magni Mesh DAC Review
Rate this DAC & HP Amp
    Votes: 42 22.1%
    Votes: 116 61.1%
    Votes: 31 16.3%
    Votes: 1 0.5%
This is a review and detailed measurements of the Schiit Magni headphone amplifier with its optional MESH DAC module. It is on kind loan from a member and costs US $199 including that option.
I previous reviewed the Schiit Magni with its off-the-shelf DAC IC. That unit had generally good performance however, it produced highly variable results. Critique was made that it was not the latest and greatest MESH DAC module. A member was kind enough to send that combo to settle the question. In this review, I will be focusing strictly on the DAC portion as the headphone amp is the same and covered in the other review. To that end, I used the RCA output:
schiit Magni Mesh™ DAC stereo headphone amplifier back panel AC transformer power supply review.jpg
It is wired in parallel with the headphone jack but likely with a series resistor. This shouldn't impact my testing.
I used the included USB cable and connected it to my USB switch.
Product was purchased in January of this year and identifies itself to Windows as MESH DAC (there is no marking on the unit itself that I could find).
Schiit Magni MESH DAC Measurements
Let's start with our usual dashboard. To get to 2 volts nominal output, I had to use the medium gain with volume control set to max:
Output was quite stable having none of the issues of the previous DAC module. It also produced lower noise and distortion, ranking the unit few steps higher:
Note that the competition is all in the blue region so this is a bit of a miss. But still competent.
Same story when it comes to dynamic range:
And filtering/frequency response:
50 mv output is slightly above average but not where it needs to be for sensitive IEMs:
Multitone turns in good numbers:
Although there is that odd spike in there.
Stereophile's 50 Hz test also looks good:
But we see some dark clouds where we don't expect in the IMD test:
At anything less that peak output, noise should dominate, not distortion. Yet we see that hump indicating non-linearities in the digital to analog conversion Our 5+ year old reference (dashed blue) doesn't have that issue whatsoever.
We saw fair bit of interreference in the noise floor of the jitter signal. Same exists here, to a smaller extent:
Linearity as I expected, also shows randomness in reproduced lower bits:
As with the original, we see elevated wideband noise+distortion in our frequency sweep:
FFT shows the same mess of noise and distortion in ultrasonics:
So I decided to investigate further. I switched out the DAC and used just the RCA input and disconnected the USB-C cable (blue):
We see a far cleaner output. I then reconnected the USB cable, while still using analog RCA input. We see that mere connection of the USB cable, without using the DAC, generates all that noise and interference sources. In other words, isolation from USB ground is poor (power is provided by the AC transformer).
In my test system, as I noted in the intro, I use a USB hub which tends to reduce my systems noise. In your system, the noise level over USB could be anything -- higher or lower. So while the instrumentation of my system points to noise that is inaudible, it may not be so on your system. This is what the output looks like by the way, from a DAC and amp combo in the same price point:
We see very little interference. There is an increasing noise floor but that is part of the noise shaping of the DAC, not noise from the USB bus.
Let me start by quoting company product description relative to the DAC: "With the optional internal Mesh™ DAC card, Magni Unity is a one-box system with uncompromising sound. "
Well, this is definitely compromised performance. The MESH DAC brings no benefit and instead, reduces measured performance in a number of areas. Electrically, noise over USB is allowed to enter the system even if you are not using the DAC -- a poor showing.
Folks spend all kind of money to reduce noise from cables to power conditioners. Yet, we have a device here that by itself, allows computer noise to enter the rest of your chain in a very easily measured way. Simple measurements like what I have performed easily identify the noise issues. The company is either not running such tests, doesn't know how to reduce impact of USB noise, or doesn't care. None of these sit well with me. They know better. This is a case of relapse in proper engineering.
I get that they want to differentiate with their own designs. But this has to provide clear user benefit, and not reduce performance. Best to put the marketing costs for the new DAC into better design or else, give up and use an IC solution like everyone else. They have plenty of differentiation already in the form of US manufacturing and support.
So, no, I can't recommend the Schiit Magni Mesh DAC. My recommendations are mine and I can't reward a product that takes a step back in performance in so many areas.
SPECS THAT MATTER
Power:
plenty for all headphones except a handful of the hardest-to-drive ones (we’re talking HE6, Tungsten, stuff like that)
Noise: inaudible on all headphones and IEMs
Distortion: unmeasurable at normal listening levels; 1000x lower than the typical headphones you're using
Heat: amp gets slightly warm without DAC card, moderately warm with DAC card; this is fine, we have made much hotter-running stuff that lasts farrrrrr past the warranty
Size: extremely desk-friendly
OTHER SPECS
Frequency Response: 20Hz-20Khz, +/-0.01dB
Output Power
Maximum Power, 16 ohms: 3.0W RMS per channel
Maximum Power, 32 ohms: 2.5W RMS per channel
Maximum Power, 50 ohms: 1.5W RMS per channel
Maximum Power, 300 ohms: 415mW RMS per channel
Maximum Power, 600 ohms: 220mW RMS per channel
THD+N
Low Gain: Less than 0.0001% (-116dB) at 2V RMS into 300 ohms
High Gain: Less than 0.0003% (-108dB) at 2V RMS into 300 ohms
IMD
Low Gain: Less than -110dB at 4V RMS into 300 ohms, CCIF
High Gain: Less than -108dB at 4V RMS into 300 ohms, CCIF
SNR
Low Gain: Greater than 122dB, referenced to 2V RMS
High Gain: Greater than 112dB, referenced to 2V RMS
Crosstalk
Less than -80dB, 20 Hz-20 kHz, 300 ohm load
Output Impedance
SE ¼” TRS output: less than 0.1 ohms
Preamp output: 75 ohms
Input Impedance: 50k ohms
Gain: 0.3 (-10dB), 1 (0db) or 5 (15db)
Topology: Fully discrete, DC coupled, current feedback, highly linear open-loop with low loop feedback
Protection: Failsafe DC power input and muting relay, overcurrent sensing and output lift, DC servo
Power Supply: 100% linear supply with “Wall wart” style 14-16VAC transformer, regulated +/-17V rails with over 8,000uF total filter capacitance
Power Consumption: 2W idle, 12W max
Size: 5 x 3.5 x 1.25”
Weight: 2 lb
This seems to be the standard corner cutting from Schitt. Their products aren't terrible, but they aren't worth the money either. At least the amp is good if all you need is that.
Schiit happens to the best of us ;) At least it's inexpensive.
USB noise turns to an epidemic as PC's, GPUs and their PSUs go stronger and stronger, despite their improved efficiency schemes.
High currents are dancing around in there.
I'm really,REALLY curious what a nice isolator chip would do to the overall cost of a DAC, any DAC.
I know the isolator chips usual prices ( not expensive, at all) and I know that higher price devices like Eversolo use them with great success.
As sources of interference tend to add up these days around our racks and desks, is it too much to ask for a proper galvanic isolation and not relay on pure luck?
Thanks Amir!
Well, it’s not a disaster and most performance is respectable, but the USB noise interference raises eyebrows. Price is low-ish but performance on the whole isn’t competitive with the best in its price class. Plus, Schiit has shown they have engineering chops to make excellent gear—just not here. Taking all of the above into account, realizing the deficiencies will probably not be audible unless you have a really noisy USB source, I’m voting “Fine.” However, it is an almost “Not Terrible.” Really on the line here.
See, this is why I don't like unbalanced anything connected via USB. The ground noise can be immensely high.
I am not surprised about once again Schiit failing to deliver anything competitive in its price point...
Even a 20 usd dongle performs better.
Hmm, seems like they forgot something. Definitely a pass for me.
I voted "Fine." Amir's "YMMV" warning about potentially higher noise than tested notwithstanding, there's nothing in these measurements that I could hear. $200 seems about the right price for something manufactured in the USA. Obviously if you don't care about that you'll find better deals from companies that have lower production and operating expenses.
My main issue with Schitt is the fairly regular rants on /r/audiophile and /r/headphones about them giving people the runaround when a product is shipped defective. But Topping and Fiio are worse (other than easy returns if you order via Amazon) and JDS doesn't have anything in this price range so again it seems to be a decent product.
As an aside I have to wonder how much time they spent coming up with their name? Maybe Stoole was already taken. It's not like KIA which was a translation or cultural issue. Seems like a lot of audio companies don't think too much about branding.
$199 for a pretty good but not great unbalanced DAC and amp is just too much in comparison to other offers these days. You can get a better performing product with more functionality for less money.
I have a suspicion Schitt knows sales and marketing much better than we do and have found people buy cutesy names and exotic topologies more than objective measurements. Subjectivists probably outweigh objectivists by a huge margin.
Having said that, we were heaping praise on the products in the list below this level of performance just a few years ago. JDS, RME, etc.
??? RME easily beat the Schiit in every measurement. Here is an example IMD:
And that is from nearly 6 years ago!
This is 100% true. They sell their products to people that watch Darko and Cheap Audioman videos. Most of their buyers care nothing for objective measurements and noise is probably a good thing to have because it gives it that different sound so many are looking for.
