TLDR: I do not understand the relationship between the volume control on my digital source and the Kara F, depending on which of the three gain settings is chosen.
I am trying to understand the different
gain options that the Kara F provides. Note that my questions come from a general lack of understanding, but since the Kara F has 3 different options available, it seems like a good case study. For context, my upstream devices are a balanced minidsp Flex and a Rega MM MK5 phono stage. I have been using an integrated amplifier for quite some time so I haven't worked through these concepts, but, now I'm on a journey to learn.
1. Passive. My understanding is that if I set the Flex to 0 dB the output is ~4 Vrms. If I set the Kara F to max volume, 4 Vrms will be output to my amp. If I turn the volume down on the Kara, the input from the Flex would be attenuated and the output from the Kara will be lower than 4 Vrms respective of 128 steps all the way down to 0 Vrms output. Given the 200 ohms output impedance of the Flex, what is the input and output impedance of the Kara in passive mode?
2. Gain 1 (0 dB). I think this can also be called unity gain? When I look up what unity gain is, it appears the output gain will be equal to the input gain. So in this case what role does the volume control on the Kara play? Again, if the output on the Flex is set to 0 dB, ~4 Vrms, and the Kara is set to max volume, I assume 4 Vrms is output, but what happens as I turn the volume knob? Is the volume knob on the Kara F rendered inactive and now I use the Flex volume knob to control output which is passed through the Kara with no gain? What about impedance? I'm struggling with the difference between passive and this option, both functionally and in terms of specifications.
3. Gain 4 (12 dB). For anyone who got this far, you can tell I am thoroughly confused. Intuitively I would assume that this option will increase the input by 12 dB. But again I have the same questions as to the function/relation of the Kara volume control to the Flex volume control when set to this mode.
My examples were within the context of the minidsp Flex as input, but I assume the only option that would make sense for my phono stage is the 12 dB gain option if I input it directly into the Kara instead of running it through the Flex.
Rega specs.
