oldsysop
- Joined
- Sep 5, 2019
- Messages
- 407
- Likes
- 705
Soundstage opened up nicely (wider, more fleshed out), phantom center strong and clear, added a warm/vintage/touch of liquidity...
I have a JJ 6922 gold pin in my Buf right now. In my setup the bass really seems to be emphasized with it. Too much so when I use my teaks. Treble seems to be rolled off some. I don’t like it with the teaks, but it works great with my r50x. It’s a bright headphone, really bright to my ears. The taming of the treble helps with that particular pair of headphones and the emphasized bass is nice with it too. To be honest though I prefer the stock tube over the JJ overall. My JJ has around 70 hours on it at this point. The sound it adds noticeably changed somewhere around the 50 hour mark. I’ve been watching several eBay auctions that have the ‘75 Voskhad 6n23p grey shield getter on a wire tubes but I’m having a hard time pulling the trigger on any of them at this point. They’re pretty much all being sold from Ukraine and I worry that won’t receive it plus if I do shipping time is listed at around 4 to 6 weeks. Many think it’s a really sweet tube though.That’s what early users reported; I haven’t tested myself to verify. On the tube side, there’s a JJ E88CC 6922 tube I may get, it’d be right about $30 shipped. Anyone have experience with that one?
what are common lifespans? 6DJ8s?Yes in fact I reckon at least a few dozen hours.
Note that unlike SS gear, tubes really do need time to warm up (literally!)
and they also routinely need replacing as they wear out.
10,000 hours is possible for preamp tubes. The 6N1P supplied is a very quiet, rugged tube that may last longer. It is not exactly a 6DJ8 or 6922 and while you can drop those in the socket and they will work, they won't necessarily match well with the circuit. A lot of 6DJ8/6922's are microphonic in higher gain circuits while the 6N1P is almost never microphonic. You might hear that in the "gain" position with this product.what are common lifespans? 6DJ8s?
I don't "need" the gain, but it i think it adds a diff sound (beyond volume of course). I did choose the "low noise/microphonics" & "balanced triodes" upon checkout from tubedepot.10,000 hours is possible for preamp tubes. The 6N1P supplied is a very quiet, rugged tube that may last longer. It is not exactly a 6DJ8 or 6922 and while you can drop those in the socket and they will work, they won't necessarily match well with the circuit. A lot of 6DJ8/6922's are microphonic in higher gain circuits while the 6N1P is almost never microphonic. You might hear that in the "gain" position with this product.
I guess I'll find out soon enough. Am hoping to capture some of that "..very lush presentation with a 3 dimensional soundstage."
www.audiosciencereview.com
Indeed -- the very definition of scope creep.more complex wiring I think, seems nuts to me
Love to see this discussion—this is my first post. I couldn’t resist registering and replying immediately once I saw like-minded people with the same equipment.The Buf seems like a fun device to play with but I have a technical question. I would be using a Topping Pre90 with an RCA output to the RCA input of the Buf. Then I would have to use an RCA to XLR cable to connect to the RCA output from the Buf to the XLR input to my Purifi Eigentakt amp. Are there any issues with this connection chain?
Some in that thread are getting two Bufs, just so it can be used with XLR, using specifically wired Wye adapter cables to shift phase then re-combine.
I want to emulate Crestron's CNXBRMO bridging interface for their CNAMPX-16X60 16-ch amp (bargain!) and it seems to be the same idea
It performs very similar to the one used in the test here:To the Buf owners: is it audible? I wouldn't want to spend on something that "doesn't work."![]()
