Voltage gain. 12 db gain equals 3.981 times the input voltage. Voltage gain in db =20log(voltage out/voltage in) - it’s math.What unit is that?
Can someone post good ELI5 links to fill in a noob's learning gaps on these units, all the "different kinds" of gain / volume?
That's huge!!Voltage gain. 12 db gain equals 3.981 times the input voltage. Voltage gain in db =20log(voltage out/voltage in) - it’s math.
Please ELI5Step 2: get another Buf. Chain the two.
Step 3: High gain from Buf 1 overdrives Buf 2 into oblivion, 100% distortion or more (you actually want this)
Don't make me get one and test it for musical purposes. It's actually very tempting, for science... and otherwise. I mean it.Please ELI5
> Aiyima T1 for even bettererer distortion
actually would be a great test comparison, of just the tube distortion part.
I'm thinking my kids might enjoy BUF as an experiment, they use BT for everything
Suggestions for a good BT receiver to go upstream and a quality transmitter to go downstream? LDAC + all the aptX's...
Single function only, for flexibility in repurposing later please, at most volume & bypass-able tone controls
Works either way, I believe - between a preamp with volume control and amp, or between a source and an integrated amp.Would one place this before or after the attenuator?
Doing some interim reading; apparently placing it before the attenuator will benefit a source with insufficient voltage, which shouldn’t be a problem in this case, but could be useful after by creating a stable load for the attenuator to see. Tu-be, or not tu-be? Why is this a question?Works either way, I believe - between a preamp with volume control and amp, or between a source and an integrated amp.
I'd prefer the opposite. Good distortion practice dictates you drive it into clipping to your liking, then attenuate after to compensate for added volume. The other way around simply doesn't allow controlled adjustment of distortion level because it can very well get too loud long before desired tone. Even if you want only a little, the principle stays.To get max "tube effect", I would prefer it last, just before the power amp if possible.
But there are gain level-matching issues unique to each system.
See my Vali 3 comment above
By this, I assume you meanyou drive it into clipping to your liking
Guess what they come over as in Germany, with their pretension and... let's generously call it unprofessionalism. "Schiit is a proud German name..." (website quote). No it isn't, none such name exists, it's the German word for Shiite, as in a member of that Muslim faith.I'm sure it's all great gear, but in the UK at least, nobody is going to buy the brand and risk coming home, saying to their wife "Look, I just bought some Schiit gear!", or have friends round and show it off to them. It's old hat I know, but I'm born evil, wicked and bad, as some of you realize, and even I wouldn't go there. They should rebrand and go for something like "Loverly" or "Ober-da" [hint: Cornish]
