Correct.Do you have it placed as the last line level device just before the power amp?
Nice spectrum! It's cheap enough to get it, mod it for infinite gain, and put in a pedal as a nice distortion effect. Should work excellently!It's harmonious! I could do without the 60 Hz noise + associated harmonics, but I'd wager that the other harmonics are exactly the "tube juice" it's designers were after. Priced right too. Chart depicts performance at 0 dB setting.
oy.Some in that thread are getting two, so can be used with XLR, using specifically wired Wye adapter cables to shift phase then re-combine.
It sounded like a fun idea, and cheap too. I ordered one.I don't have test equipment, but in case anyone's interested, I got mine today. Very well built and does exactly what it says: colors the sound. I'll save you all the crazy adjectives, but it's very pleasing to my ears. Definely sounds better than most of the Fosi/Aiyima/etc "tube buffers" I've heard and adds a nice punch to the low end.
I hate to use this description.... But the soundstage does appear wider to me. Everything audio is subjective, so take this witha grain of salt, but to me, it's worth the asking price.
I wish they had a balanced version with XLR. I would buy it for 2x the priceI don't have test equipment, but in case anyone's interested, I got mine today. Very well built and does exactly what it says: colors the sound. I'll save you all the crazy adjectives, but it's very pleasing to my ears. Definely sounds better than most of the Fosi/Aiyima/etc "tube buffers" I've heard and adds a nice punch to the low end.
Shht, balancing stages are like 5 moneys in parts DIY, can run it off the internal power rails...I wish they had a balanced version with XLR. I would buy it for 2x the price![]()
You just buy two and wire it with Wye adapters.I wish they had a balanced version with XLR. I would buy it for 2x the price![]()
Well that's a silly solution as that would alter the effect of the even harmonics which are said to contain the tube magic.Some in that thread are getting two, so can be used with XLR, using specifically wired Wye adapter cables to shift phase then re-combine.
Interesting! but pricey no?Well that's a silly solution as that would alter the effect of the even harmonics which are said to contain the tube magic.
Instead they should buy a line transformer. That will give even more 'tube-ness' and add some odd harmonics and can be connected to a balanced input.
