bboris77
- Joined
- Oct 23, 2018
- Messages
- 450
- Likes
- 935
To quote Sean Connery: “Shocking! Positively shocking!”Its probably the best use of a 2k+ power cable. To play your music in the bathtub just one last time.
Ah I realize that its actually 300ohm here. When I first saw the graph I thought it was 32 ohm not 300 ohm.... had a brain fart I guess. That is a decent amount of power for 300 ohm considering the price. Not sure if anyone would need that much power but its always nice to have!It has a ton of power for difficult to drive headphones. You can't replicate that with other amps no matter how much lower their distortion may be.
Here is Atom:
Here is Asgard 3:
Atom produces 250 milliwatts whereas Asgard 3 goes up to 650 milliwatts or nearly three times as much.
The Asgard 3 also has a metal case that stays put and has built-in transformer rather than a big chunk externally.
Atom is wonderful and great value at $99 but there are different reasons for it existing beside Asgard 3.
Once you have 95+db its hard to hear a difference with most content.I already own an Asgard 3 and a Modius. I’m trying to understand the graphs more clearly so I can correlate what I’m seeing with what I’m hearing. I also own an Element II, which to my ear sounds pretty much identical to the Asgard paired with the Modius.
That is also true. There are definitely worse options for more money.True, there are cheaper options that measure a bit better for low impedance and high sensitivity headphones. In practice though, that probably doesn‘t make much of a difference. I wouldn‘t specifically recommend this thing with analog volume control and mediocre noise for those kinds of headphones, but it isn‘t bad either, there are worse options for a lot more money for sure.
Yes basically everything about the company is toilet jokes. Including the performance of many of its product which can be considered to be "in the toilet".Does this company deliberately riff on toilet jokes? The reason I ask is that it is a pretty easy permutation of Shiit Asgard to Sh*t As*gard.
Is so powerful that I don't see the point, high gain is enough to make me use my most demanding headphones at 9 o'clock.Ah I realize that its actually 300ohm here. When I first saw the graph I thought it was 32 ohm not 300 ohm.... had a brain fart I guess. That is a decent amount of power for 300 ohm considering the price. Not sure if anyone would need that much power but its always nice to have!
I don't disagree. Even with my "heavy planars" I dont need more than 11 oclock volume on my Geshelli Archel2 Pro on low gain for most music. However if I am listening to some streamed live news broadcast with horrible audio I might use like 2 oclock. But this isn't the fault of the amp, just the horrible broadcast.Is so powerful that I don't see the point, high gain is enough to make me use my most demanding headphones at 9 o'clock.
Very few. In this blind test with over 500 participants, perhaps only one or two. A vast majority of audiophiles are imagining things (myself included).I want to know how many, if any , audio sommeliers we have amongst us.
Is more than you need, I even use my LCD-2 in low gain. Planars need more current than voltage. Use this website to see your power needs: https://www.headphonesty.com/headphone-power-calculator/Low gain max power at 33 ohm is only 150mw vs high gain 3400mw. Interesting. Is high gain usable with Ananda ? 25 ohm 103db/mw sens
It is a combination of voltage, current, impedance, and sensitivity. That was a generalization since most planars are low impedance, but the specifics of each driver determine their needs.Doesn’t that depend on the specific drivers rather than type? Eg., LCD-4 is 200 ohm.
150 mw is low though.Is more than you need, I even use my LCD-2 in low gain. Planars need more current than voltage. Use this website to see your power needs: https://www.headphonesty.com/headphone-power-calculator/
No, you can get your Ananda up to 103 dB with 1 mW, that's rather high.150 mw is low though.
The overall purpose of a higher powered amp isn’t necessarily to play music as loudly as possible, it’s more about maintaining the accuracy of the loud transient peaks and preserving the recording’s dynamic range. This makes the presentation of those complex musical sound waves as natural and clean as possible without clipping, resulting in high quality, distortion-free sound.
I understand what you're saying (I've read that article already), but this amplifier has more than enough headroom for any transient you want to play (at least if you don't want to blow your ears). My LCD-2 are more insensitive than your Ananda (only 93 dB/mW) and I use them in low gain (better performance in terms of distortion and SINAD), I don't go past 12 o'clock in this setting with these headphones. High gain is more useful for headphones that have more impedance (they need more voltage and less current). Trust me, you won't clip this amp with the Ananda unless you want to blow your ears in the process.This is interesting read about power from Audeze: https://www.audeze.com/blogs/technology-and-innovation/sensitivity-impedance-and-amplifier-power
hecking out power calculations from your link it says 500mW for 130db, 5W for 140db. Let's say we are listening around 80-90db and have a loudness peaks like 40-50db as Audeze mention. It means we need that headroom. 80+50= 130db, 90+50=140db.
