Sb Acoustics SB26ADC in Pureshape + Purifi PTT8
Here is some more progress pictures
Wow! The measurements look perfect, and so do your building skills! I'm looking forward to seeing how the Purifi driver works with this amazing waveguide/horn. Will it be a closed box design? Passive or active?
Will be ported box its 52L and with passive crossover
Boxes now with first layer of final paint. I measured the horn response every time i applied paint/filler to be sure that im not painting the throat too much.
Got one purifi driver so i can now start to design crossover for these. Too bad that my tweeter response isnt as perfect anymore bcouse of the diffraction from the purifi surrounds but thats fine :D
Here is some measurements the 2 polar plots and inverted polarity test measurements are real measurements. This is still test crossover. The CEA Plot has only vertical measurements to 30 degrees For each driver and 0-90 horizontally. Its not far from final crossover. Box is still sealed and without any dampening :D
very nice to see your project and your measurements - you could try to turn your woofer 1/6th to get a different interaction with your tweeter - the surround will be more inside than outside and it is less symmetrical
Yea i tried it. Surround causes some diffraction at 3-7khz range but its not end of the world.
Here are horizontal measurements from probably the final crossover
very nice result - is it necessary to loose 4db between 75 and 25hz? - i understand you try to filter the speaker to a flat horeizontal curve - but when listening to music I like a downward-tilted slope
F3 is about 27-28hz. This is constant directivity with 90x60 degree coverage so works better with 2m+ listening distance. This speaker is also easy to eq to if you want less highs you can easily do it but i aim for flat on axis design then you can eq if you like. This actually sounds more balanced vs my other similar kind of speaker but with wider radiation 120degree and more downward tilt. The ”Target” curves very much depend on the listening distances and room and speakers coverage area.
Looks like a nice speaker. I looked at the waveguide myself but was a bit hesitant since they only published H3 distorsion. How does it look in your measurements?
Its extremely low even at my 1.1khz crossover which im testing now. Pureshape gives 10-11db loading at the low end. Just have to be careful with tweeter when crossed that low it could get warm if you push it hard.
Here is couple of pics from finished speaker. I still dont have the other woofer
Numbers would be really nice since the supplier is only publishing 3rd order distorsion.
That is a mighty fine looking speaker sir.
I really do wish I knew how to even start making a x-over.
