- Thread Starter
- #361
Here you go, not the best picture I ever took...Do you have any internal pics of the Arthur 5523/E1?
A couple additional notes where it looks like there might have been some copy/paste errors:@boXem Hello Fred, on your website I noticed some errors in the Description and Product details of the Arthur 4216/E1.
In the Description: "In the Arthur 4216/E1, the amplification stage can deliver up to 375 W in 8 Ω and 1050 W in 2 Ω." doesn't seem right. In the Product details the Reference and Power stage(s) don't seem right.
Could you please check?
Edit: typos
Edit: typos
Corrected, thanks guys!A couple additional notes where it looks like there might have been some copy/paste errors:
In the 4216/E2 product description under "Purifi Eigentakt technology" it identifies the wrong Purifi module:
For the Arthur 4216/E2 we have chosen to implement the Purifi Eigentakt technology with the 1ET9040BA amplification stage.
Then as Nordling noted, it also lists higher power output (probably corresponding to the specs for the 1ET9040BA.
Finally, in the Product Details, the "Power Stage(s)" is incorrectly identified as the "Purifi 1ET9040BA".
The two additional wires are here to enable a biwiring option. As you can see, this option is not available on our amplifier, partially due to the lack of space, partially due to my personal opinion on biwiring.There should be two more cables for the outputs that are not yet connected.
Why is the full potential of the new module not being used, as described in the data sheet?
A few?????? I think 350 watts is just a bit more than a few.If, like I suspect, you are wondering why a few Watt are missing in 2R, it is due to the power supply chosen. I won't discuss the choice of PS any further, it is anyhow taboo on this site.
Congratulations for a new product which push the limit into such a small candybox!!! I'm surprised today as I saw the new Arthur 4216/E2, but it seem the board specification still not corrected, is this the correct one "Purifi 1ET6525SA power stage"? And the power delivered in different load:Corrected, thanks guys!
argh I think so, because I look wrongly, it was the mono amp I'm lookingThese parameters are correct, the Purifi 1ET6525SA replaces the famous 1ET400A and gains some Watt in heavy loads due to what appears to be an even better efficiency.
O.K. Do you have a measurement of one of the unaffected amps? Your development tests or production QC tests?Purifi sent us improperly calibrated modules. We had to ship back our entire stock and are waiting the parts back. At the moment we are stuck, not only on the measurement side.
Before the subject comes, amplifiers sent to customers are not impacted by this calibration issue.
