Satellites for 115 dB/m: DIY or Pre-built recommendations (CamillaDSP active setup, 200 Hz crossover)
You also got the fairly compact MEH design from Scott Hinson, that is highly regarded:
My jbl am6212/00
Uses a jbl 2206h woofer and 2431h compression driver on a very good horn (pth1010hf)
I am using Adam T8V's for this. They do 112dB full range, maybe they can do 115dB when crossed at 200?
I just checked: the A4V can do this >200Hz
No it can't they were tested down here and already distort quiet a lot at 96dB. Just like most small hifi speakers. Dome tweeters and ribbon tweeters are not made to play that loud and neighter are small woofers. You need compression drivers and bigger woofers for that.
If you want <1% distortion at 115dB that will be quite a challenge..
What levels of distortion are you looking for?
