EfrenSanani
- Joined
- Sep 21, 2024
- Messages
- 5
- Likes
- 8
I am pleased to show you my homemade stereo integrated amplifier made from parts.
Materials used
Amplifier: Ice Power 200AS2 (integrated source)
Transmitter-Up2 Stream HD-Dac
Secondary power supplies: Meanwell PD-25A (12 V and 5 V)
Vumeters- TN-73 and TS-003 board.
Chassis: Aliexpress
Front panel: Express front panel
Potentiometer - modified from Eizz, it arrived damaged and I modified it to have stepped touch.
Features
A two position momentary rotary switch was used to turn on and toggle input.
In order to control the ignition with the voice assistant a wifi switch was installed, which was also perfect for me as I was able to use a momentary switch and not have to sync the rim light.
A remote control for the streamer has been included: taking advantage of the Vumeter glass, the IR has been glued in so that it works properly and no extra holes are drilled. The performance and range is excellent.
Final Photos:
Wiring
Placa Amplificadora Ice Power 200AS2
Streamer HD DAC Arylic Up2Stream
Fuente de alimentacion dual
Specifications:
Input
PCB Connector
RJ45
Output
Coaxial SPDIF
I2S
Optical Toslink
PCB Connector
RCA
DAC / ADC Chip
ES9038Q2M
Max sampling rate
192kHz
Streaming services & Network protocols
Amazon Music
Qobuz
Spotify
Spotify Connect
Tidal
Tidal Connect
Materials used
Chassis: Aliexpress
Features
Final Photos:
Wiring
Specifications:
| 215 W (4 Ω) 120 W (8 Ω) | ||
| 3.5 Ω | ||
| Maximum total amp+psu efficiency | 70 % | ||
| Supply voltage input | 100-240 VAC | ||
| Peak output current | 13 A | ||
| Dynamic range |
| Amplifier maximum output voltage per channel |
| Output referenced idle noise (A-weighted) |
| THD+N 10 W/1 kHz | 0.004 % |
Input
PCB Connector
RJ45
Output
Coaxial SPDIF
I2S
Optical Toslink
PCB Connector
RCA
DAC / ADC Chip
ES9038Q2M
Max sampling rate
192kHz
Bluethooth aptX HD
AirPlayAmazon Music
Qobuz
Spotify
Spotify Connect
Tidal
Tidal Connect
