JoyK
- Joined
- Mar 22, 2026
- Messages
- 7
- Likes
- 0
Hello,
I have been in the process of setting up a multi-zone setup. I was able to get a good deal on a Samson S-Zone (https://samsontech.com/products/mixers/rack-mixers/szone/), which has a lot of features that I liked/wanted. However, there seems to be a lot of buzzing noise produced by it. Here are some things I have played and tested around with it:
If anyone has advice or require more information in order to give advice, please let me know and I'll do my best to respond.
Thank you.
- Using grounded and not grounded outlets. It doesn't seem to make any difference and the noise stays the same.
- Different cables and different inputs/outputs. Same results. In fact, the mixer has a monitor on it, which when nothing is even plugged in (minus the power), the buzzing noise becomes apparent and louder once its volume control reaches around 40%+. It is even possible to hear the buzzing at lower volumes once you know it's there.
- I have looked inside at its guts and it's clean. As far as I know, it looks fine to my beginner eye.
- I have tried different power cables. No difference.
- I have tested and use a combination of either powered or amp + passive speakers. Both behave similarly to how much buzzing occurs. The powered speakers will create a loud "pop" sound if they're connected to the mixer and I turn it on.
Thank you.
