SACD ISO file(disc image file) conversion process
What's the easiest way to convert a SACD ISO file to transfer to my DAP? It's a disc image file.
I assume after extraction it becomes a DSF file?
Thank You for the input.
Run the ISO through Sonore ISO2DSD (File Input) and Output Mode: Sony DSF.
If your DAP can handle DSF file you are set, if not, do a batch convert to FLAC using JRiver or a similar tool. Note, JRiver can batch convert on the fly to a DAP which saves a step and you don't end up with duplicates.
Roon can transcode on the fly via ARC which is how I would enjoy them while driving around. :)
Whiuch is entirely down to the recording and mastering.
Not by virtue of it being DSD. Something else would have to be different about the mastering.
Also, 'mastering in DSD' is rather difficult. Mastering is typically done in a >1bit environment.
