Hello All
I am a new-comer to this forum, though i have been reading your posts and reviews for many years. I should probably thank you all for your fantastic discussions which i have found informative.
This has been discussed time and again, but i am still quite confused. So here goes nothing! I want to play SACD through my HiFi stack, and am investigating two possibilities:
DIY solution
I have a Sony Blu-Ray Player which i want to hook up to my HiFi for SACD playback. It outputs via HDMI. It has the usual SPDIF outs but i know (thanks to you folks) that this wont work for SACDs, as it would downsample to CD quality. I have gone down the rabbit hole on this, and looked at HDMI extractors, and then connecting the NON-standard I2S pin-outs to a ES9039Q2M DAC board (imported from China). It seems Theoretically possible, but I am a novice so, i am always reluctant to jump in for a 'DIY project' - especially where i could damage my equipment. As i havent found anyone who has done this, i am quite reluctant, even though on paper it should work. The plan would be an Extractor (HDMI I2S COAX) - wired directly to a ES9039Q2M DAC board - which would TECHNICALLY be capable of DSD native decoding. Technically better on paper, but i am VERY unsure, as i have found NO ONE who has done this!
The BDP is set to DSD - it handshakes with the HDMI Extractor - Then i use the independant pins on the Extractors I2S Output headers to connect to the DAC board, which has I2S input.
(screen grabs of the boards below)
Actual HDMI IN PCM DAC
While researching DIY solutions, I came across the product screen grabbed below on a chinese site - unusually for this area, it has what appear to be 2 HDMI Inputs. The ARC output is a non issue - i have no interest in BluRay or Video playback. This is purely for my Hifi. Many of its features are also surplus to requirements for me, as i have another DAC which i use
(All inputs on my existing DAC are in use, its a ZD3, and i love it - not interested in using it for todays purposes)
So my questions would be as follows
I am aware of SACD extraction - I have played DSD files over on my ZD3 - Totally get that this is easier, and i avail of this right now. The purposes of this FINAL upgrade to my stack is straightforward. The ability to play SACDs in my player through my HIFI.
Im sorry if this has been covered. Its been discussed so many times, and i have seen various degrees of success. I havent really encountered anyone with the DIY solution, although i found discussions on the topic! As for the Chinese Import DAC below, it does seem viable as a straightforward ALL-IN-ONE box, albeit for HiRES PCM as opposed to NATIVE DSD
Thanks so much folks - Hope to hear back from you! (PS - if this post is in the wrong section, please feel free to move it)
DIY solution
- has anyone attempted this
- Is it a non starter (im waiting for the other shoe to fall on this one, as it seems too straight forward)
- Will this box handshake with my Sony BDP thereby not tripping the SACD 'DRM' Trap
- If i set the BDP to PCM output, will it transport PCM to the unit below
- Is this unit's ESS Sabre ES9023P DAC sufficient for the task
- I am ONLY interested in 2CH - my amateur assumption here is that settings in the BDP for 2CH, and on the unit, will prioritize 2CH SACD, and or DOWNMIX 6CH to Stereo
- Is this unit a significant bottleneck for my system
