Due to overwhelming ASR member demand (kidding) I thought it would be interesting to compare three high-performing DAC/amp combos: the Sabaj D5 vs. the SMSL M500 vs. the Topping DX7 Pro. Thanks to
@amirm for all of the measurements; all of this info is from him (unless otherwise noted), I'm simply putting the measurements side-by-side.
Author's notes:
- Sabaj --> SMSL --> Topping is simply alphabetical; I'm not implying one is better than the other.
- All of the graphics are labeled, but to make it consistent: Sabaj D5 is always on the left, SMSL M500 in the middle, Topping DX7 Pro is always on the right.
- I have no experience with any of these units, nor do I have any perspective on build quality / customer service.
- If anyone sees errors / omissions please let me know and I will make corrections.
- If anyone has issues with the measurements or conclusions ...... take it up with Amir!
BASIC SPECS
This is not an exhaustive list.
References:
Shared Specs:
- DAC chip: ESS ES9038PRO
- XLR line outputs: yes
- Remote control: yes
Varying Specs:
- USB: Sabaj D5 & Topping DX7 Pro = XMOS XU-208 // SMSL M500 = XMOS XU-216
- XLR headphone jack: Sabaj D5 + Topping DX7 Pro only
- Bluetooth: Topping DX7 Pro only (Bluetooth 5.0 with support for LDAC, AAC, aptX, aptX LL, and aptX HD)
- MQA: SMSL M500 only
- Optical input(s): Sabaj D5 (x1) // SMSL M500 (x2) // Topping DX7 Pro (x1)
Dimensions:
- Sabaj D5: 24.5cm (W) x 21.0cm (D) x 5.0cm (H)
- SMSL M500: 8.8cm (W) x 19.7cm (D) x 8.5cm (H)
- Topping DX7 Pro: 22.2cm (W) x 17.8cm (D) x 4.5cm (H)
On to the DAC measurements ........
- Note: For the SMSL M500 output was measured at 4.3 volt, not the ~4.0 volt of the other two DAC/amps.
- You can click on each image to enlarge it.
SINAD
Measured using USB in / XLR out. However, the Sabaj D5 measurements were taken after
30 minutes of warm-up.
DYNAMIC RANGE
JITTER
INTERMODULATION + NOISE
A slight "ESS IMD hump" appears in the Sabaj D5 and Topping DX7 Pro units.
- Note: the SMSL M500 has both the XLR and RCA outs measured.
LINEARITY
All three units are capable of 20 bits of resolution.
- Note: The Topping DX7 Pro only has the XLR out measured; it does not include the RCA out.
32 TONE INPUT SIGNAL (192 kHz)
THD+N RATIO vs FREQUENCY @ 48 kHZ
FFT SPECTRUM OF WHITE NOISE @ 44.1 kHZ
For the DX7 Pro, please note
this discussion regarding the filters between
@Veri and Amir. As Amir states: "
... either the manual or the firmware may be wrong."
*Note
there is now a revised user manual for the DX7 Pro. The original manual -- which is what Amir used -- listed the filters in the wrong order. The new, corrected manual is in the same "Drivers and Documents" section of Topping's website: http://www.tpdz.net/support.html
The following are the headphone amp measurements ...
SIGNAL to NOISE RATIO (50mv | 600 Ohm)
I didn't find this for the Sabaj D5, so only the SMSL M500 and Topping DX7 Pro are pictured.
POWER VS. DISTORTION (300 Ohm load)
POWER VS. DISTORTION (33 Ohm load)
POWER VS. DISTORTION (XLR out using 50 Ohm load)
Only the Sabaj D5 and Topping DX7 Pro are pictured. As Amir mentions in this thread: the M500 does not have an XLR headphone out, so it was not tested.
CHANNEL IMBALANCE
I didn't find this for the SMSL M500, so only the Sabaj D5 and Topping DX7 Pro are pictured.
OUTPUT IMPEDANCE
I believe Amir has previously stated that his test equipment adds about 0.8-0.9 Ohms? If that's the case you can subtract that amount from each of these measurements.
CONCLUSIONS
Sabaj D5
From Amir:
SMSL M500
From Amir:
Topping DX7 Pro
From Amir:
