I would recommend check the voltage selection and fuse. Also try another power cable.Hi i recieved today directly from sabaj store . Its not turning on can anyone help please.
how to check voltage selection ?I would recommend check the voltage selection and fuse. Also try another power cable.
i did try my pc power cable too its not workingI would recommend check the voltage selection and fuse. Also try another power cable.
It's on the back of the unit, next to the power inlet.how to check voltage selection ?
There is a power selector in the back. It's usually covered by a sticker. Most likely the selector is in the right position but still check it.how to check voltage selection ?
i did all of that nothing helps . did check fuse too its acting like a dead brickThere is a power selector in the back. It's usually covered by a sticker. Most likely the selector is in the right position but still check it.
A bad power button maybe? Have you tried to use remote to power on?i just dont know what to do . I noticed when i opened fuse and put it back i saw red light on the button for split second
i dont have baterries for remoteA bad power button maybe? Have you tried to use remote to power on?
idkGlad he got it working.. How can a brand new product have a blown fuse tho
Impedance | Sensitivity | FR | |
| HE400i (v2015) | 35Ω | 93dB | 20Hz-35KHz |
| Edition XS | 18Ω | 92dB | 8Hz-50kHz |
ok thanks if buy amp can i use d5 as dac onlyMy D5 drives a pair of HiFiMan HE400i's, the 2015 version. Comparing the key specs:
Impedance Sensitivity FRHE400i (v2015) 35Ω 93dB 20Hz-35KHzEdition XS 18Ω 92dB 8Hz-50kHz
From my experience I can just barely drive my HE400i's to full volume (for my ears at least) when using PEQ via the 1/4 headphone jack. If I really want ear-splitting levels I have to switch over to the XLR headphone out.
That said I don't know much about headphone specs, so I don't know if your Edition XS's -- because of the differences in impedance and sensitivity -- are somehow that much harder to drive than a pair of HE400i's. Or if the power required to drive these two is not that much different, then is there potentially an issue with your D5, your power source, your XLR cable, etc?
Obviously some of the best headphone amps that Amir has reviewed deliver significantly more power than the D5; it's not a standout amp in that regard. The Monoprice THX 887, for example, can drive 3.7 watts (50 Ohm load via XLR, on High gain). That's almost triple what the D5 can do for a 50 Ohm load via XLR.
thank you i will write if i will buy ampYes, easily. If you go that route one consideration is to get an amp with balanced (XLR) inputs, and use XLR interconnects between the D5 and the headphone amp. You certainly don’t have to do this, but using balanced connections between the two devices can help resolve ground loop issues that might exist.
Something so simple that sometimes we just forget it exists.Just circling back on the issue that @georgek558 was experiencing with the Sabaj D5. Turns out it was a blown fuse.
For anyone else that might run into this problem: the Sabaj D5 uses 0.5 Amp / 250V fuses.
