Sabaj A30a announced
Thank you, @Roland68, do the Dunlavys have very, very low impedance at 80–100kHz (is that 80kHz?)....
Got only plots on those? Given that these things just have a regular dome tweeter, they should not have a falling impedance with frequency unless they did something stupid with the crossovers.
There are two versions of VMV A2 (corresponding to manual version 1 and version 1.2), the the menu of A2 V1 is without sub cutoff option (same as the one amirm measured), but with additional amp gain control. According to SMSL tech support, V1 cannot be updated to V1.2 by firmware, so V1 and V1.2 might have different hardware implementation. A2 V1.2 is same hardware as A30a.
Thank you, @Dsggolv77, Yes, that the SMSL VMV A2/V1 (as measured by amirm) cannot be updated to V1.2 by firmware, suggests as you have indicated/mentioned, that the SMSL A2/V1.2 and Sabaj A30a are not an identical hardware/design to the SMSL VMV A2/V1, doesn't it? This implys that the V1 and V1.2 Measure/s will/may not be the same, which is reasonable?
Once, noticed a Measure of the Sabaj A30a/V1.2, indicateing that the THD+N was >103dB (if it can, again, be found/located) then this also would indicate/support what you have indicated/mentioned, wouldn't it? Manufacturer Claims/Specs, of the Sabaj A30a/V1.2, suggests.... THD+N 0.0008%/SINAD 102dB, SNR 116 dB, Crosstalk/Channel separation 108 dB, which indicate High Performance (Higher than SMSL VMV A2/V1), don't they?
Thank you, @Dsggolv77, the SMSL VMV A2/V1 THD+N was about 95/96dB (as measured by amirm), wasn't it? So if the Sabaj A30a/V1.2 is not an identical hardware/design then the Manufacturers Claim/Spec with a THD+N 0.0008%/SINAD 102dB, might actually be correct. That is a 6/7dB improvement, isn't it? It would also explain why many like the Sabaj A30a, wouldn't it :=)
Perhaps best to ask @Roland68, he knows the internals of both quite/very well, and can better discuss your findings/post....
Thank you, @Vlasis, your reply suggests >4R minimum, doesn't it, which should not cause the Sabaj A30a shutting down issue, should it? How old are the Dunlavys? How loud are the loud transients, such as what is the volume setting, which input (Analogue/SPDIF/USB/etc), what is your Sabaj A30a Version, anything else that you might consider helpful in assisting to evaluate the issue.
It is working, you are enjoying it, let us see (Together/All) if we can isolate the issue....
There are no differences between the devices—at least not regarding the components.
I have attached the official measurement data for both units.
The issue regarding the analog input measurements stemmed from a misconception. The analog input utilizes the PCM1804 ADC; however, in this specific implementation, the analog input's performance falls short compared to other designs featuring the PCM1804.
First off: there has always been only one version of the A30a.
I also do not believe that a genuine "V1.2" version of the VMV A2 ever actually existed; had it done so, SMSL surely would have advertised it as such.
Instead, I suspect that a critical connection was inadvertently omitted during the PCB's design or manufacturing phase, and was subsequently added—either during the next production batch or via a retroactive modification.
Presumably, the A30a benefited from its later release date, ensuring that this particular error was not repeated.
All the menus for sound customization and subwoofer control are powered by the STA309A DSP chip.
Furthermore, regarding the various speculations about differing measurement results—specifically in relation to the design and component changes—you are all falling victim to the same logical fallacy.
This amplifier operates entirely in the digital domain from input to output (with the sole exception of the dedicated analog input). There are no op-amps, no potentiometers, and no analog signal path. How, then, could the measurement results vary so drastically?
It is only at the output stage that the digital signals are converted into analog PWM by the Axign chip.
Incidentally, the VMV A2 has also been discontinued and removed from the website.
Re The A30a also ran without any issues with 2-ohm speakers in my setup.... that is good to know :=)
Hi @Roland68, if 80K–100kHz is the issue, with the A30a to Dunlavys Mid/High +ve connection, would it be ok/acceptable to add an inductor in-line, set for say 50K-60KHz or even 40K-50KHz, at the Dunlavys Mid/High +ve connection?
We’ve already covered this topic a few times in this thread—most recently just a few pages back.
A resistor and/or an inductor proved to be the effective solution in those instances as well.
It would be even better if someone were to simulate the crossover network.
As far as I recall, all similar issues in the past have consistently pointed to extremely low impedance in the crossover within this high-frequency range.
Thank you, @Roland68, Yes, but note that this is not for me, it is for @Vlasis....
  • Apologys, No, last time it was for a pair of Magnepan speakers (inductor in series from about 12-15kHz)....
I had the chance to listen to the Sabaj A30a and ended up taking some photos of the inside and i could not find the AXIGN chip anywhere...the amp sounded fine but it kept shutting down on loud transients...may be you guys can comment about these photos?
@Vlasis, if you can find an Impedance Graph for your Dunlavy speakers, that will be helpful :=)
  • You have mentioned fairly benign but conciseness will be helpful....
Exactly—and if you look at the thread history, everything suggests that the low impedance in the high-frequency range dropped all the way down to zero at the higher, inaudible frequencies.
The point here is not that there is any signal present in this range, but rather that the amplifier is subjected to a short circuit within this frequency spectrum. That is a major and fundamental distinction.
For the Dunlavy 3a
  • Nominal: 4 ohms
  • Typical range: ~3 ohms (low‑frequency minimum) to ~6.5 ohms (high‑frequency maximum) US Audio Mart+1
  • Low‑frequency minimum: ~2.9 ohms at ~63 Hz Stereophile
  • High‑frequency maximum: ~6.5 ohms US Audio Mart
Apologys, @Vlasis, best left to @Roland68 and @voodooless to assist you with this. Note that, as the Sabaj A30a is working, it could (simplely) be Thermal Shutdown, why?.... the enclosure is not Ventilated, is it? High Volume and Enclosure Temperature would be an indicator. The minimum Impedances, mentioned, indicate no issue/s, there, don't they/reasonable?
