What’s the point of upsampling on a device that resamples back to at 44.1 kHz?
Don’t you have the option, or do you not get sound? In the first case, you may need a driver to make it work. Default USB audio drivers may not expose all sample rates.Just curious , specs say it should but it doesn’t
That's just down to your upsampling software or settings.There is no sound or very distorted sound , I’m using a Mac so no drivers
Try another USB cable.There is no sound or very distorted sound , I’m using a Mac so no drivers
Tried that still the sameTry another USB cable.
Audio midi says 768 and 768 is on the dacThat's just down to your upsampling software or settings.
Have you checked the settings in your Audio-MIDI-Setup.app?
Real 768 kHz files are displayed that way when played.
But as @voodooless said, the A30a only plays 44.1 kHz. Upsampling has a rather negative effect there.
Do you mean that 768 kHz is displayed on A30a, or on another DAC?Audio midi says 768 and 768 is on the dac
Sorry i meant the A30a, i have tried a few different cables.Do you mean that 768 kHz is displayed on A30a, or on another DAC?
Are you using the original cable from the A30a or another USB cable.
My advice is to stop worrying about it.Sorry i meant the A30a, i have tried a few different cables.
Are you suggesting this because there is an up sampling then down sampling to 44.1 kHz PCM, 2 processes/transcodings, which means the original signal is changed/transcoded with the up sampling (which is not good and as such, a massive waste of bits), therefore unnecessary especially as down sampling to 44.1 kHz would require much more processing effort by the A30a and the original signal is further changed/transcoded by the down sampling process?Anything above 96kHz is a massive waste of bits, and a waste of the effort you are putting in trying to make it work.
No, I'm stating (not suggesting) that 48Khz is fully capable of delivering the full bandwidth that the human ear is capable of detecting.Are you suggesting this because there is an up sampling then down sampling to 44.1 kHz PCM, 2 processes/transcodings, which means the original signal is changed/transcoded with the up sampling (which is not good and as such, a massive waste of bits), therefore unnecessary especially as down sampling to 44.1 kHz would require much more processing effort by the A30a and the original signal is further changed/transcoded by the down sampling process?
Perhaps it is better if you can explain it better in your words?
Let's make it simple: If you can play original files at 768 kHz perfectly on the A30a, then the problem must be with the upsampling.Sorry i meant the A30a, i have tried a few different cables.
This is how proper Gentlemen interact, well done chaps.@antcollinet, thanks for the insight! I understand your point of view. So SACD/DSD is then also an analog signal, according to your logic?
... And worst of all, for all the Axign fans, that chip is just an (extra)ordinary DAC, just one that it outputs PWM![]()
Good point. If real files play, and the upsampled version does not, it may be a CPU load issue or simply a bug in JRiver...Let's make it simple: If you can play original files at 768 kHz perfectly on the A30a, then the problem must be with the upsampling.
It could suggested that until PWM can be played through passive speakers, and enjoyed (edit: enjoyable experience), that it is yet to be defined as analogue but a type of digital (even like FM (called digital) or even like DSD (called digital)).... that is reasonable, isn't it?@antcollinet, thanks for the insight! I understand your point of view. So SACD/DSD is then also an analog signal, according to your logic?
Why don't you just replace the UK plug on that cable?I would like to change the American power cord/plug that was sent to me from sabaj (I live in the United Kingdom).
