There is zero proof of that..in practice, higher is better
Actually, there is, but as I hadn't indicated what would be better or why, it's clear you are merely looking for an argument.There is zero proof of that..
Are you kidding me? Someone reacts to an almost 2 year old post of mine with an ad hominem and now I’m looking for an argument?Actually, there is, but as I hadn't indicated what would be better or why, it's clear you are merely looking for an argument.
-Good luck with that.
I now see Guerilla was correct.
I do think you’re wrong about there being “zero proof” that higher is better.Are you kidding me? Someone reacts to an almost 2 year old post of mine with an ad hominem and now I’m looking for an argument?
If you think I’m wrong, tell me how and why with reason and logic, not with assertions or pointless ad hominems.
And yes, my answer to you was also just an assertion.. see how annoying that is?
This is not because of non-perfect clocks, it’s to give the filter time to attenuate enough while maintaining enough passband.First of all, a slightly higher sampling rate should be used to be sure you don’t cut off too low, because clocks are not perfect.
Yes, that’s what the theorem says.In other words, the sampling frequency must be higher than the 2x the highest frequency to be replicated.
Not with proper filtering.Of course, anything excessively high can allow aliasing,
Well, that’s my main point really. Adding more samples doesn’t add more information in the bandwidth you need it. That’s what the theorem is all about. 192 kHz doesn’t give more information below 20 kHz than 44.1 kHz sampling.so 'higher is better' is not an open-ended statement.
I don’t think (non)-sinusoidal is a proper term for this. It’s about capturing the information of a bandwidth limited signal, and for that the sampling theorem applies, no matter the wave shape. That’s why you have to band-limit the signal before you do the capturing. If you want to capture a square wave, choose how much bandwidth you want to spend on it, and pick a sampling frequency accordingly. Higher rates in this case, may yield a better result in your scope. And you can argue that it better represents the original. That’s fine, no argument there.All good, so far. But for some non-sinusoidal waveforms, such as triangle waves, or square waves, you need to consider the highest frequency component of the signal. That’s practically impossible, depending on your fidelity goals, because triangle waves and square waves are not bandwidth-limited in nature. In these cases, ‘higher is better’ – within reason.
-I know, an argument can be made that non-sinusoidal wave replication is outside the area of interest in an audio forum, but that’s an opinion, not a fact.
I view zero order hold broken by designEven in sinusoidal, bandwidth-limited replication, oversampling can reduce approximation error in many modern DACs that use zero-order-hold for example. In these cases ‘higher is better’.
Was it? I didn't see you make that point. You didn't make any point.Well, that’s my main point really.
Yes, that was the topic almost 2 years ago.Was it? I didn't see you make that point. You didn't make any point.
No I don’t, and the reason is already explained in my previous posts: leave some room for the filter to do its task and move all effects of it out of the audible band.I wasn't reading those 2 year old messages (just the one Guerilla referred to, because you invited education...)
-but now that I go back and check your reference.....
and what do I find?
- Is this voodooless preferring to see higher sampling rate than the 2x maximum frequency of interest?
- but why, even with "zero proof"? /s
You seem to be self-contradicting, arguing for the sake of arguing...
After all, the filtered sub-out is a penalty to the a30a..
Can’t them make a firmware that runs the sub-out full-range?
I've already asked twice and even offered help the second time, but there was no response.I'm fairly confident they can make a firmware version that does add a full-range output to the SW, but I seriously doubt they would. It seems like a bad business decision, to invest time & resources (testing) for a f/w update, for an almost non-existent market demand. A full-range mono output may be useful to you for an outdoor sound reinforcement, but it's not likely to be a very popular option on a stereo amp, even a 2.1.
That said, it never hurts to ask - try to contact someone at SMSL/Sabaj.
A quick look at the datasheet shows that it basically should have most of the basic bass management features of a modern AVR, including proper channel mixing, crossover selection and large/small settings for the main speakers. Highest crossover seems to be 160Hz by default, but I suspect you can do stuff with custom biquads as well.Due to the ICs used in the device, it is very likely that full range sub-out is not possible, as are other changes to the 2.1 functionality.
Its not a problem or a limitation. As long as sub does what its supposed to, there's no reason for the mains to go lower. When low cut they play cleaner with less distortion. Keeps its woofers further away from their xmax and their coils in the magnet field. You bought speakers that goes unnessary low, but that's just a luxury-problem.Unfortunately, if it works like that, it won't work in my application. I hoped that the sub output would also work without a filter, and that the subwoofer itself would filter. Sabaja's crossover frequency of 70 Hz is too high, hecos can play really low.
Hi to all,Hi every one
I am interested in this Sabaj. Has any one compared it to the SMSL ao300, which is my current amp ?
Thx
Which amp specifically, SMSL has a very wide range of amp products.Way better than the SMSL.
Hi to all,
I ended up buying this Sabaj. Way better than the SMSL. Everything is better. It drives my speakers with authority and refinement. I am glad I bought it !
