I considered both and bought the Sabaj. In my setup I need a control by an IR remote.Would you consider this amp better than the JDS Atom AMP+ or similar (diminishingly different) sounding?
Yes, it powers on automatically with the previous volume settings.If unplugged, and then power applied, does it come on, or do you have to turn it on? I power my system with a sequencer.
Does it come on to the same volume as when turned off even of there is no power applied?
FYI, using RCA to XLR adapter (1 ft long), connect to a long XLR cable to XLR input of my amp, solved the ground loop issue.You can't do what I did. Audio Precision RCA ports are floating (kind of like balanced). That gives me the then the option of where to earth them. Your audio gear has already made that decision for you which unfortunately then leads to ground loops in some cases. Resolving these problems can be a nightmare and a matter of luck. This is why I always recommend balanced connections if you can get them.
I've just ordered this, upgrading from my Atom v1 mainly for the remote resistor volume control.Maybe an update. The A20h arrived and I've been using it for a week. @SMSL-Mandy @SMSL_Liu if you could get hifi-express to ship @amirm one that would be awesome. I PMed him and he's not aware of any going his way. For shame..
That out of the way, let me review the full order/user experience first some negatives
- I ordered from "EU Warehouse" but it was shipped from China from a service called "Yanwen". Full delivery took 16 days.. just shy over 2 weeks. Not terrible but not fast. I'll give it a pass though given corona/package overload, and the fact that customs and duties were at least included
- On first plug-in I had buzzing using SE in/out. I then tested it further using XLR in SE out, and also tested it using an RCA>XLR adapter. Funnily enough after cleaning up my desk/workroom and hooking it all up again I am now using RCA in SE out with 0 noise in all case except for '0dB' volume in high gain, I need to use -1dB with RCA in to have an absolutely noise-free experience. Plenty loud for me.. but fair to mention.
Perhaps there was another charger or cellular device disturbing the amp. Or after plugging into each and every input/output I fixed whatever was weird out of the box- Knob is what it is not being analogue and all, it doesn't stretch out far from the case but the resistor clicks make up for the otherwise "okay" experience.
On to the positives:
- Very competitive to Topping A90. I really like the resistor volume and the remote control. Hard to beat, an awesome and usually very expensive feature at this price point.
- Power is pretty ridiculous. Normal listening volume is at lowest gain at -30dB with 600ohm HD600/HD650, this is with full 4-4.5Vrms input though, 100% system volume but ~-6dB digital volume applied in digital EQ. 4V minus 6dB would mean that default 2V input without EQ would achieve the same. This can definitely power Beyerdynamic 600Ω / Hifiman Arya/HEK/HE-6 level of headphones.
- On that note. On my Topping L30 I used ~60% system volume so I could easily use all gain on normal knob levels (low with IEMs, medium/high with needy headphones depending on EQ used). On this one given the resistor volume network, I try to maximise volume on software side (100% on OS, 95% on application side to ensure no clipping or Windows volume limiting).
Perhaps placebo, I'd be willing to admit it, but using max volume + resistor volume control seems to have proven to be an upgrade over my trusty L30 amp. I'm really liking the Sabaj A20h. SE in SE out / BAL in SE out would already power most traditional headphones to perfect degree. BAL in / BAL out would be there for extremely needy headphones, would not bother for other use cases, it'll just be really loud really quickly.
Another positive, to me, is the headphone port on the back. I actually like this in terms of cable management. All cables are plugged neatly behind my desk. Sure, mostly any amp has this port in front. And most people would prefer it this way. But for me this works
Overall would endorse this balanced Sabaj A20h product. Very nice work.
Using mine just about every day hope you'll like it! Which source will you use?I've just ordered this, upgrading from my Atom v1 mainly for the remote resistor volume control.
I use mine everyday as well and it’s definitely worth upgrading to.Using mine just about every day hope you'll like it! Which source will you use?
I’ve got a d50s, not balanced but it should not matter much.Using mine just about every day hope you'll like it! Which source will you use?
I see, should be fine with single-ended input, won't matter much except with super sensitive IEMs maybe since they will magnify any noise, with my headphones it is 100% noise free at least.I’ve got a d50s, not balanced but it should not matter much.
Any news? Is the case connected to the chinch mass?Since the power cord only has a 2-pin connection, neither the power supply unit nor the A10h can be grounded through it.
I would have to test at the weekend whether the mass of the housing is connected to the chinch mass.
Cost and implementation. Analog pots are simpler and cheaper.Wow. Why no one else uses this type of volume control ? It's accurate and have a nice visual and sensory feedback. It should be norm.
Cost shouldn't be an excuse. There are a lot of overpriced uninspired products. Topping just released DX5 for example. It could have used this feature to differentiate itself a bit. Also this Sabaj is cheap af.Cost and implementation. Analog pots are simpler and cheaper.
You're speaking to my soul. Especially when I see (or rather hear) what a large channel deviation my Singxer SA-1 has at the beginning and end of the turning range, and the Sabaj A10h is perfect throughout.Wow. Why no one else uses this type of volume control ? It's accurate and have a nice visual and sensory feedback. It should be norm.
Those SMSL products quite nice. I think there is also the Gustard one. Topping falling behind.You're speaking to my soul. Especially when I see (or rather hear) what a large channel deviation my Singxer SA-1 has at the beginning and end of the turning range, and the Sabaj A10h is perfect throughout.
The SMSL SH-9 and SP400 use it, as do many expensive/high-end devices, e.g. Niimbus.
With such a solution we are not talking about high costs (MQA is more expensive ;o), but about something more than the potentiometer. You can get ready-made DIY circuit boards for around $30. Balanced is twice as expensive in both cases (all relays, resistors and transistors x2), but it would have been worth paying a premium for the SA-1.
Incidentally, this solution is much less sensitive to ESD (and the resulting overvoltage/DC) since the potentiometer is no longer in the signal path.
If it's all about channel equality, there have also been cheap versions of rotary potentiometers with SMD resistors for $10 - 20 for a few years. I can't understand why they aren't used.
I think SMSL, Loxjie and Sabaj are all from the same parent company. I may be mistaken though.Those SMSL products quite nice. I think there is also the Gustard one. Topping falling behind.
Yeah i'm still looking for that ''perfect'' product but no one coming out with it. No reason to spend money.I think SMSL, Loxjie and Sabaj are all from the same parent company. I may be mistaken though.
But yeah, I almost considered getting the a10h already having the topping L30 just for the digital control and remote, but refrained because I would lose a bit of money in doing so.
