JSmith
You mean getting an answer to the below?Good luck.
so what was the device you compared to this Sabaj during this level matched, blind A/B?
JSmith
Topping dx5 and topping l50 with e50 dac.You mean getting an answer to the below?
JSmith
Which filters were selected?Topping dx5 and topping l30 with e50 dac.
Default ones. I cannot hear the difference between them (maybe there is something but in blind test i failed) so don't play with them.Which filters were selected?
JSmith
What kind of attitude is that?Lol. Good luck.
Ps. Sorry for triggering you.
I won't disturb you anymore.
I forgot that it's SCIENCE
Topping was just a bit clearer.
Of.course the change was not big but still.
As @JohnYang1997 said. Dx5 has better headphone output performance. And I believe you can hear that. At least I was able to hear the difference.
I don't own dx5 and e50l50. I was visiting my friend. Comparison was made more like system vs system. Not particular outputs into the same amp - I had no desire to do so.Do you get the same problem with the DAC outputs of your A10d (e.g, A10d as a DAC for your Dx5)?
Only for some measurements addicted dudes.If an issue is at least -20dB below the threshold of hearing and probably lower than that, is it really an issue?
One is sent to me but I don't think it is here yet.The A20d looks even more better with that display, will you review the new A20d @amirm ?
Been lurking for a while and registered to ask this.
Between this sabaj for 299 and the loxjie d30 for 259, which would you choose and why? Thinking of finally embarking into this audio hobby
I'm a complete noob in audio science but love to listen to music and currently using edifier r1280dbs w/ a klipsch r12swi connected to the subout and also use my PC w/ peace/equalizerAPO from this site.
thanks in advance
Hi,One is sent to me but I don't think it is here yet.
