I have been using the PO100 Pro for quite some time now and can only recommend it to a limited extent.
There are no problems with low quality (AAC/MP3 radio streams). But a Qobuz subscription quickly revealed the limitations of this device.
As long as you listen to the same quality, everything is fine, even up to 24-bit/192 kHz.
However, if you have a playlist with frequently changing quality, there are often disruptions (distortion, dropouts, regular crackling) when transitioning to higher quality (24-bit/48 kHz and above).
You then have to pause playback and restart to fix the problem. In my opinion, things like this should not happen.
