I have a PO100 Pro which works well. However, for the MQA decoding, it only outputs 88.2 and 96k despite what the indicator light says (which is usually higher the the two sample rates it ends up outputting). Has anyone else experienced this?
That is absolutely correct.I have a PO100 Pro which works well. However, for the MQA decoding, it only outputs 88.2 and 96k despite what the indicator light says (which is usually higher the the two sample rates it ends up outputting). Has anyone else experienced this?
No, the same technology that is in the PO100 and Pro is also installed in the MDA1.Hi. Will there be a change in sound quality when connecting po100 to smsl mda1 (coax or optical) compared to connecting to USB directly?
Nope. But I'm not sure how this would be useful (if connecting a streamer via USB output?)Hi. Will there be a change in sound quality when connecting po100 to smsl mda1 (coax or optical) compared to connecting to USB directly?
I want to connect my phone via usb if the sound is worse via bluetooth.Nope. But I'm not sure how this would be useful (if connecting a streamer via USB output?)
You could connect your phone straight to the MDA1 as well. Unless you also need the USB input for your PC ?I want to connect my phone via usb if the sound is worse via bluetooth.
I have also a laptop that has only usb outputs. In fact, the PO100 is also a DAC, so it turns out that there will be two DACs or not?You could connect your phone straight to the MDA1 as well. Unless you also need the USB input for your PC ?
The PO100 is only a DDC (digital-digital converter), not a DAC.I have also a laptop that has only usb outputs. In fact, the PO100 is also a DAC, so it turns out that there will be two DACs or not?
Only the PO100 AK is. The rest of the line is USB to S/PDIF converters.In fact, the PO100 is also a DAC,
Take a look at the first page of the thread.I would need a USB to optical and SMSL interface seems to be of good quality.
However, the PO100 model appears to use a single oscillator that implies use of PLL or ASRC for the missing frequencies family.
It's ok for costs saving, but technically I don't think it's SOTA.
I understand that the measurements here are downstream of the E70 topping, so the measured jitter performance is not purely the PO100 ones.
Does anyone know which family is the oscillator mounted on the PO100 and/or has measured the actual jitter?
I have read, but I cannot find answers to my questions. That's why I have postedTake a look at the first page of the thread.
Jitter measurements are also included.I have read, but I cannot find answers to my questions. That's why I have posted
Yes, the Pro seems to use 3 oscillators, with the third one supposedly at 24MHz for HDMI. Technically it seems more correct, but before spending more I would like certain what the PO100 does.Jitter measurements are also included.
Alternatively, you can take a look at the PO100 Pro.
There are significantly more sophisticated interfaces from Singxer, Gustard, and others, but they're in the price range of perfectly measured DACs, such as the DO400, D400 ES, RAW Pro-DAC1, and Loxjie D40 Pro.
do you know of a device like po100 but with an optical spdif input or hdmi input in addition to USB? The PO100 works well with my PC, but now i want to connect my TV to the same device as well as PC
www.audiosciencereview.com
SMSL PO100AK, PS200, SU-1, C100, DO100 Pro HDMI ARK……do you know of a device like po100 but with an optical spdif input or hdmi input in addition to USB? The PO100 works well with my PC, but now i want to connect my TV to the same device as well as PC
