I have had a close look at those measurements. I find it somewhat odd that a loudspeaker that has a specification of being –6dB at 47 Hz has such a strong response down at 35 Hz. It doesn't seem to make sense in light of the fact that the ASR measurements seem to support the published specifications within a few hertz. It would seem that your LS50s have extended their bass response by almost an octave, and now have the low-frequency response that one would expect from larger floor-standing loudspeakers.
There is a reason for this - KEF have a signature low-end curve in most of their ported speakers. They tune the port low to have a gradual roll-off from 80-100Hz to the port frequency, with energy being redirected to low bass. They're targetting more even in-room response at low frequency, on the assumption they'll get room reinforcement.
Most manufacturers seem to tune their ports higher to immediately pick up and extend the anechoic linear region of their response as much as possible, but after that it drops sharply.
In their current Reference range, KEF actually supply two different port lengths you can use to choose between the two options, and these diagrams from the white paper illustrate the two responses (both relative to a sealed box in green). Long port (normal KEF response) is in blue, and short port (Reference alternative, similar to other speakers) is in purple.
The choice of tuning doesn't massively affect the -3dB or -6dB value, so doesn't really show up on the specs. (eg Reference 1 is -3dB at 45Hz with either port, and -6dB only shifts from 40Hz to 37Hz).
But it means you get unusually extended in-room response - as long as you've got a room with solid walls able to help. Conversely KEFs will struggle (relative to other speakers with the same -3dB values) in some rooms, and only the References provide the alternative port to help with that.
Jack Oclee-Brown
discusses the Reference tuning here (and grumbles about the bungs used for tuning in their cheaper products).
