Rumble from Turntable Bearing?
AndyMorris
From Vinyl rips I have done and processed in Audacity and Vinyl Studio, I have recently noticed a rumble with a period of 0.12 seconds. This is equivalent to 8 Hz. It beats with a period of 1.8 seconds, which is 33 1/3 times per minute. The rumble amplitude at the maximum of the beat is about -30 db.
Obviously, as I am not an elephant I cannot hear this, but it does raise some questions in my mind:
  • Is it reasonable to assume this is caused by the main bearing on the turntable?
  • Are the bearings on the turntable on their way out? I estimate, from my collection on Discogs that I have played more than 500 records on this (mid price, DJ style KAM ) turntable. Mostly LPs a few singles and some 78s
  • Will this inaudible, which is removed by Vinyl Studio, cause any other distortion?
I would love to hear anyone's opinions oof what is going on here. Do I have a good excuse to get a new TT?
The following screen shots are from the lead-in groove of a good quality LP:
Frequency of rumble
Period of beat
I would love to hear anyone's opinions of what is going on here. Do I have a good excuse to get a new TT?
Once every revolution points to the bearing. If the platter lifts off easily so you can clean and lube the bearing, you could try that. Otherwise, you have a good reason to buy a new turntable.
Most likely it is the resonance frequency of the cartridge + warps and eccentricity.
-30dB rumble would be pretty bad, but I would want to make sure it's not the record(s) before replacing the turntable.
Whatever it is, a 20-30Hz high pass filter should reduce it drastically. It's probably a good idea to filter it out. (Most records don't have a lot of energy below 40Hz anyway.)
Vinyl just has abysmal rumble. It's good practice to hard cut everything below 15khz.
YES!
What I do:
My Technics SL-M3's TT Rumble: -82dB
Turn on the 15Hz infrasonic filter:
The low-frequency response is the same with the tone controls either defeated or engaged, for all inputs and all outputs.
The 15 Hz filter is selected with a rear-panel switch.
It's -1/2 dB at 20 Hz, -1 dB at 17.5 Hz, -2 dB at 15 Hz, -3 dB at 14 Hz, - 5 dB at 12 Hz and -10 dB at 10 Hz.
15 Hz filter (only) response.
Problem solved.
YES!
What I do:
Problem solved.
My preamp (Spartan 15) has a brilliantly deep cut in that area. No point in your speakers pumping for no good reason. Plus, waveforms look so much cleaner without that ripple running through them.
Reactions: EJ3
This is out of my 1977 APT/Holman Pre Amp (the Tom Holman that invented LUCAS sound for the movies, THX, 5.1 surround sound [and more]).
DSP can kill super low frequencies without affecting music.
One day, (if I feel what I have isn't enough) I'll add DSP into my processor loop (maybe). Since I have subs that I built that cover 20Hz-80Hz, they may surprise me and I may determine that I need DSP.
But: I think -92 @ 10 Hz is just fine (TT rumble -82Db + infrasonic -10 Db filter cut.
It's certainly inaudible when taking room noise into account.
I do not use a weight to hold the record flat, I use a pad (from K.A.B.) that grips the spindle and holds the label area flat, thus reducing warp.
That way I avoid having much extra weight on the bearing.
KAB SUPER RECORD GRIP MK2
[td]
KAB USA RECORD GRIP
[/td]​
  • Molded Phenolic
  • Color: Black
  • Footprint: 3"
  • Height: 1"
  • Weight: 2 Oz.
  • Max Spindle Height: 3/4"
  • Bubble Level Accuracy: 1°
  • Shipping Weight: 6 Oz.
Claims:
  • Effective Damping
  • Easy To Use
  • Better Bass
  • More Detail & Focus
  • Quick Check Level
Easy enough to eliminate at 8hz, so that would be my approach. Just another vinyl issue that comes with the territory, tho
