theglobalelite
- Joined
- Jun 27, 2020
- Messages
- 91
- Likes
- 143
As an experiment to try to reduce bass sounds overheard by neighbors*, I attached these SVS SoundPath Subwoofer Isolation Feet to my floorstanding Paradigm Monitor 9 speakers. They are "designed" and primarily advertised for subwoofers use, but it's really just a simple rubber donut so I figured it might be a worth a shot to try with speakers. I did some research prior to buying and found a few other users who tried the feet with their floorstanders and noticed no audible difference, also contacted SVS who said they should work fine on the floorstanders.
The results were not good! Bass became noticeably more boomy and bloated with less impact. And I got MORE noise complaints!*. I've only gotten 1 noise complaint in 3 years, but after installing these, I got 2 in 2 weeks! It must be transmitting more bass through the floor?!
My question is, does this make any sense? I didn't expect to get the exact opposite of the intended isolation effect. Rubber is a very common isolation material and should have some isolating effect, no?
I'm quite certain it's only transmitting lower and mid bass (~50-90hz) frequencies to neighbors because it's a modern upscale complex with concrete slabs between units. I don't hear any loud noises (above 100hz) from any neighbors, but I do hear EDM bass bumping from the unit directly above me. So I can only assume the unit below me hears bass frequencies from me, hence this experiment with isolation feet.
*I truly try to not be the dickhead neighbor who blasts music all hours of the day, I seriously try to keep a reasonable volume at reasonable times.
