I wouldn't say it's helping very much. First let's make sure that the measurements are comparable, we'll look at the the overlay between "Right Bare" and "Right Treatment":
Yup, exactly the same pattern of reflections that sit on top of each other exactly. This means the microphone was not moved between "treatment" and "no treatment". We see the same with the left, so we'll move on.
And this is a comparison of right with/without treatment. We can see that it has improved things A LITTLE, by dropping the RT60 about 100ms between 300-600Hz. This is why it is important to check the ETC to make sure the mic was not moved - if his room is small, 300-600Hz is right smack in the middle of the transition zone where you EXPECT measurements to vary by A LOT depending on where the mic was positioned.
Depending on the size of the room and intended application, I would not be happy with this result. Especially with that huge forest of early reflections in the ETC. Some of those may be measurement artefacts (the most common is because someone is using that UMIK-1 mini tripod). Also, don't be too quick to deploy room treatment. Dr. Toole says that the target RT60 can usually be achieved with normal room furnishings. That's what I would go for first, it makes your house more liveable and improves the acoustics at the same time.
